Normal Topic App crashes on 3+ touch events (Read 3203 times)
ChrisK
May 13th, 2015 at 5:57pm
When using 3+ fingers to swipe from left -> right on the view so that you keep dragging even though the chart is already all the way to the left. This causes a crash that kills the whole application.
This is with v1.2.
05-13 10:53:49.810    9981-9981/com.example.test01 E/InputEventReceiver﹕ Exception dispatching input event.
05-13 10:53:49.812    9981-9981/com.example.test01 E/AndroidRuntime﹕ FATAL EXCEPTION: main
    Process: com.example.test01, PID: 9981
    java.lang.NullPointerException: Attempt to read from field 'float android.graphics.PointF.x' on a null object reference
            at com.mindfusion.diagramming.Utilities.distance(SourceFile:2330)
            at com.mindfusion.diagramming.DiagramView.onTouchEvent(SourceFile:415)
            at android.view.View.dispatchTouchEvent(View.java:8471)
            at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:2399)
            at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2092)
            at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:2405)
            at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:2106)
            at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchTouchEvent(P
honeWindow.java:2369)
            at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent(PhoneWindow
.java:1719)
            at android.app.Activity.dispatchTouchEvent(Activity.java:2742)
            at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchEvent(PhoneW
indow.java:2330)
            at android.view.View.dispatchPointerEvent(View.java:8666)
            at android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent(ViewRootImpl
.java:4123)
            at android.view.ViewRootImpl$ViewPostImeInputStage.onProcess(ViewRootImpl.java:3989
            at android.view.ViewRootImpl$InputStage.deliver(ViewRootImpl.java:3544)
            at android.view.ViewRootImpl$InputStage.onDeliverToNext(ViewRootImpl.java:3597)
            at android.view.ViewRootImpl$InputStage.forward(ViewRootImpl.java:3563)
            at android.view.ViewRootImpl$AsyncInputStage.forward(ViewRootImpl.java:3680)
            at android.view.ViewRootImpl$InputStage.apply(ViewRootImpl.java:3571)
            at android.view.ViewRootImpl$AsyncInputStage.apply(ViewRootImpl.java:3737)
            at android.view.ViewRootImpl.deliverInputEvent(ViewRootImpl.java:5807)
            at android.view.ViewRootImpl.doProcessInputEvents(ViewRootImpl.java:5781)
            at android.view.ViewRootImpl.enqueueInputEvent(ViewRootImpl.java:5752)
            at android.view.ViewRootImpl$WindowInputEventReceiver.onInputEvent(ViewRootImpl.jav
a:5897)
            at android.view.InputEventReceiver.dispatchInputEvent(InputEventReceiver.java:185)
            at android.view.InputEventReceiver.nativeConsumeBatchedInputEvents(Native Method)
            at android.view.InputEventReceiver.consumeBatchedInputEvents(InputEventReceiver.jav
a:176)
            at android.view.ViewRootImpl.doConsumeBatchedInput(ViewRootImpl.java:5868)
            at android.view.ViewRootImpl$ConsumeBatchedInputRunnable.run(ViewRootImpl.java:5920
            at android.view.Choreographer$CallbackRecord.run(Choreographer.java:767)
            at android.view.Choreographer.doCallbacks(Choreographer.java:580)
            at android.view.Choreographer.doFrame(Choreographer.java:548)
            at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:753)
            at android.os.Handler.handleCallback(Handler.java:739)
            at android.os.Handler.dispatchMessage(Handler.java:95)
            at android.os.Looper.loop(Looper.java:135)
            at android.app.ActivityThread.main(ActivityThread.
Re: App crashes on 3+ touch events
Reply #1 - May 14th, 2015 at 9:34am
This build should fix the exception:
https://mindfusion.eu/_temp/DroidDiagram.zip
However the component does not support gestures with more than two touches, if you add a third touch it will be ignored.
ChrisK
Reply #2 - May 14th, 2015 at 5:21pm
Thanks a lot. Yep, it makes sense that 3+ are ignored, just the crashing should happen Smiley
