Normal Topic Need help with DiagramLink.drawArrowhead() (Read 4724 times)
RickSalut
May 25th, 2015 at 7:12pm
I'm trying to figure out how to define different arrow heads for a DiagramLink and I found method drawArrowhead() but I'm bit lost with the method's parameters...
Would it be possible to get a sample of code that does a simple link with 2 different arrow heads looking like the attached picture.
Thank's a lot.
Re: Need help with DiagramLink.drawArrowhead()
Reply #1 - May 26th, 2015 at 7:31am
Set the BaseShape property of a link to draw arrowhead at start point:
link.setBaseShape(ArrowHeads.Quill);
link.setHeadShape(ArrowHeads.Quill);
link.setBrush(new SolidBrush(Color.black));
You could also define a custom Shape instance to use as arrowhead, where link's end point is mapped to 50,0 point in Shape's percent coordinates.
The drawArrowhead method is just a helper to let you draw arrowhead shapes if you render links yourself from a custom class' draw() override.
RickSalut
Reply #2 - Jun 1st, 2015 at 1:43pm
Thank's a lot for your quick answer.  It could not be more simple than that...
By the way, we have been using jDiagram for about a year now and are really enjoying it.  And you've been providing great support as well, if only every company was like you!!
Reply #3 - Jun 1st, 2015 at 3:59pm
You're welcome Cool
