Normal Topic Issue with CompositeNode Template (Read 3029 times)
Jonathan Terrell
May 26th, 2015 at 10:04pm
Hi, I have been attempting to create a custom node that inherits from CompositeNode. Everything works very well, except for my xml template. No mater what I try with column widths and row heights the columns and rows are always evenly distributed across the width or height of the node. That is each column has the same width and each row has the same height. The examples indicate that you can control the widths of columns and heights of rows. My program has no logic other than to populate the image and text components. I have include my template below. Any guidance would be appreciated. Thanks, Jonathan
<SimplePanel>
    <Shape Name="shape" Shape="Rectangle"/>
    <Border>
        <GridPanel>
            <GridPanel.Columns>
                <GridColumn Width="1"/>
                <GridColumn/>
            </GridPanel.Columns>
            <GridPanel.Rows>
                <GridRow Height="75"/>
                <GridRow Height="1"/>
                <GridRow/>
            </GridPanel.Rows>
            <StackPanel Orientation="Horizontal">
                <Image Name="image"/>
                <Text Name="text"/>
            </StackPanel>
            <Shape GridColumn="1" GridRow="1" Name="divider" Shape="Rectangle"/>
            <Text GridColumn="1" GridRow="2" Name="description"/>
        </GridPanel>
    </Border>
</SimplePanel>
Re: Issue with CompositeNode Template
Reply #1 - May 27th, 2015 at 12:04pm
This build should fix that:
https://mindfusion.eu/_temp/DroidDiagram.zip
Jonathan Terrell
Reply #2 - May 29th, 2015 at 9:29am
Works. Thank you
