Normal Topic How to use DiagramNode.AttachTo() method? (Read 3089 times)
esri_test
Jun 5th, 2015 at 8:47pm
I have a particular question about DiagramNode.AttachTo() method, especially about
DiagramNode.AttachTo (DiagramNode, AttachToNode)
I am trying to attach a child node to a parent node. for example, I want to attach to top right corner of the parent node, when I use diagram.Factory.CreateShapeNode(point, size) to create the child node, I need to calculate the center point for the child point based on the parent node point and size. It seems AttachToNode.TopRight doesn't do much.
I thought this AttachToNode enumerator will move the child node to top right corner to the parent node. And when I create the child node, CreateShapeNode(point, size) point argument can be anything?
What is correct way to use this?
Re: How to use DiagramNode.AttachTo() method?
Reply #1 - Jun 6th, 2015 at 9:29am
It should look like this:
var parent = diagram.Factory.CreateShapeNode(100, 100, 100, 60);
var childSize = new Size(20, 20);
var child = diagram.Factory.CreateShapeNode(
	parent.Bounds.TopRight - (Vector)childSize / 2, childSize);
child.AttachTo(parent, AttachToNode.TopRight);
The corner parameter of AttachTo only specifies which corner to follow when the parent node is resized, preserving initial distance from child to that corner. AttachTo does not move the node but only records its offset from argument, because the corner alone does not identify desired child position - you might want it centered, inner- or outer- aligned, with padding space added, etc.
esri_test
Reply #2 - Jun 8th, 2015 at 9:04pm
Thanks!
