Normal Topic the performance of diagramLinkStyle (Read 3971 times)
ricman400
Jun 15th, 2015 at 5:33am
i has 5000 node and links, that is the code
  foreach (var item in diagram.Nodes)
                item.RenderNode(Color.Black);
            foreach (var item in diagram.Links.ToList())
                item.RenderLink(Color.Black);
     public static void RenderLink(this DiagramLink link, Color color)
            if (link == null)
                return;
            if (link.Style == null)
                link.Style = new DiagramLinkStyle();
            DiagramLinkStyle style = link.Style as DiagramLinkStyle;
            style.Stroke = new SolidBrush(color);
            style.HeadStroke = new SolidBrush(color);
            style.Brush = new SolidBrush(color);
   public static void RenderNode(this DiagramNode node, Color color)
            if (node == null)
                return;
            node.Brush = new SolidBrush(color);
            node.Pen = new MPen(color);
but The CPU at 50%
why? what kind of solution?
Re: the performance of diagramLinkStyle
Reply #1 - Jun 15th, 2015 at 5:41am
At what time can you see CPU at 50%?
ricman400
Reply #2 - Jun 15th, 2015 at 5:46am
Stoyo wrote on Jun 15th, 2015 at 5:41am:
When it was running the code.
you can test create 5000 nodes and links ,winform ,button click run this code .the result is cpu at 50%
My machine dual-core CPU,intel core I3
Reply #3 - Jun 15th, 2015 at 6:04am
If all of your nodes and links will be painted in same colors, you could avoid creating the thousands of style and brush objects. E.g. add a "DiagramLinkStyle linkStyle" field to your form and assign it to all links from the loop instead of calling DiagramLinkStyle and Brush constructors from each iteration. You could avoid these loops altogether if you set the default styles through the Diagram's DiagramLinkStyle and ShapeNodeStyle properties.
ricman400
Reply #4 - Jun 16th, 2015 at 2:46am
Stoyo wrote on Jun 15th, 2015 at 6:04am:
Thank you Stoyan,that helps
