Normal Topic Zoom to fit not working (Read 4711 times)
ChrisK
Jul 2nd, 2015 at 8:53pm
On a DiagramView the method zoomToFit() doesn't seem to do anything. My chart is zoomed in still. I'd ideally like it so that it's an overview of the whole thing.
DiagramView diagView = (DiagramView) findViewById(R.id.diagview);
diagView.setBehavior(Behavior.Pan);
diagView.setAntiAlias(SmoothingMode.AntiAlias);
diagView.zoomToFit();
Re: Zoom to fit not working
Reply #1 - Jul 3rd, 2015 at 6:09am
Have you populated your diagram before calling zoomToFit? It sets ZoomFactor just once to fit current diagram contents, and won't continue zooming out automatically as you add new nodes.
ChrisK
Reply #2 - Jul 4th, 2015 at 1:27am
That makes sense, I've moved it after I create and populate my diagram.
layout.arrange(diagram);
and then call zoomToFit()
But that did not do anything either.
Reply #3 - Jul 6th, 2015 at 8:16am
Are you sure there aren't any calls to zoom methods done later? E.g. replace the zoomToFit above with setZoomFactor(10) to see if the DiagramView will draw at 10% scale.
ChrisK
Reply #4 - Jul 8th, 2015 at 3:44am
Yes, that works OK, it zooms out a lot.
diagView.setZoom(10);
Reply #5 - Jul 8th, 2015 at 7:23am
zoomToFit result depends on current size of DiagramView. What are you seeing in log window if you print out view's getWidth() and getHeight() values?
