Normal Topic MindFusion.Reporting for WinForms 2.3 (Read 3672 times)
Jul 15th, 2015 at 12:08pm
MindFusion.Reporting for WinForms 2.3 has been released. It adds the following new features:
Visual Studio 2015 support
MindFusion.Reporting now includes support for Visual Studio 2015. The installer can create VS2015 toolbox palette for the component.
Licensing
There is no separate trial build of the control assemblies anymore. Instead, set the LicenseKey property of the individual components to disable the component's evaluation mode and stop displaying trial messages. If your application contains more than one control by MindFusion, you could call MindFusion.Licensing.LicenseManager.AddLicense(key) to specify the key once instead of setting it per each control. License key strings are listed on the Keys & Downloads page at MindFusion's customer portal.
Barcodes
MindFusion.Reporting reports can now display UPC-A, UPC-E, EAN-8, EAN-13, and QR barcodes. The barcodes are represented by the new Barcode report item.
The component is available for download here:
https://mindfusion.eu/ReportingTrial.zip
The component is also available on Nuget. To install the component, run the following command in the Package Manager Console:
PM> Install-Package MindFusion.Reporting
Additional information about the library can be found in the Online Documentation:
http://www.mindfusion.eu/onlinehelp/mindfusionreporting/index.htm
