Normal Topic link.getPen() vs link.getEffectivePen()?? (Read 3787 times)
RickSalut
Jul 24th, 2015 at 4:30pm
I'm trying to figure out what is the difference between DiagramLink methods getPen() and getEffectivePen().
Actually, I'm facing a problem where I'm trying to change a link width but keeping its color and style, and when I use getPen() to do so, it returns null and this is not what I'm expecting...
Could anyone tell me the differences between these two methods, and/or letting me know how I could solve my problem.
Here is an example to help you understand my problem.
link.setPen(new Pen(link.getPen().getWidth()+1, link.getPen().getColor(), link.getPen().getDashStyle()));
In my case getPen() returns null, and getEffectivePen() has some bad side effects (changes link colors when I select a node or scroll down my diagram).
Thank's in advance.
Re: link.getPen() vs link.getEffectivePen()??
Reply #1 - Jul 24th, 2015 at 5:09pm
The control uses a styling system where pens and brushes could be specified by a global theme, item's style or a property. getEffectivePen returns the Pen instance that should be used for drawing, first probing for the local Pen property defined via setPen/getPen. If its value is null as by default, it looks for pen attributes in styles (DiagramItem.setStyle/getStyle) and diagram's theme. You could clone Pen from EffectivePen when you need to change thickness, and set it back to null to display the theme's pen again.
Pen pen = (Pen)link.getEffectivePen().clone();
pen.setWidth(pen.getWidth() + 1);
link.setPen(pen); // now getEffectivePen returns this one
// later...
link.setPen(null); // getEffectivePen returns default pen from theme
RickSalut
Reply #2 - Jul 24th, 2015 at 5:24pm
Thank's a lot for the quick reply.  It did solve my problem.
