Normal Topic Border Radius and Cell Padding for TableNode (Read 4657 times)
Santosh
Aug 17th, 2015 at 6:49am
Is there a way to add cell padding and border radius to a TableNode?
Re: Border Radius and Cell Padding for TableNode
Reply #1 - Aug 17th, 2015 at 8:44am
Try this:
var SimpleShape = MindFusion.Diagramming.SimpleShape;
var Thickness = MindFusion.Drawing.Thickness;
table.setShape(SimpleShape.RoundedRectangle);
table.getCell(0, 0).setText("test test");
table.getCell(0, 0).text.margin = new Thickness(5, 1, 2, 1);
Santosh
Reply #2 - Aug 17th, 2015 at 8:55am
Hi Stoyo,
SimpleShape is being displayed as invalid attribute for Mindfusion.Diagramming.
Reply #3 - Aug 17th, 2015 at 9:13am
SimpleShape has been added in last release (v2.4):
http://mindfusion.eu/Forum/YaBB.pl?num=1433927601
Santosh
Reply #4 - Oct 1st, 2015 at 7:33am
Hi Stoyo,
The image in the cell(0,0) needs to have a padding at the top. I tried to increase the row width. Did not work out.
Following creates my node. What do I need to change, to add top-padding to the image in cell(0,0)
Code (Javascript)
function buildHeaderTableNode(tableWidth, text, imgLocation, tooltip){
    var tableNode = diagram.getFactory().createTableNode(10, 30, 40, 18);
    //tableNode.setCellFrameStyle('transparent');
    tableNode.setFont(fontStyle);
    tableNode.setTextColor('black');
    tableNode.setBrush('white');
    tableNode.setStroke('#999999');
    tableNode.setTag('transparent');
    tableNode.redimTable(5, 5);
    tableNode.columnStyle = ColumnStyle.AutoWidth;
    tableNode.setCaptionHeight(0);
    tableNode.setShape(SimpleShape.RoundedRectangle);
    tableNode.setStrokeThickness(1);
    tableNode.setTooltip(tooltip);
    var cell00 = tableNode.getCell(0, 0);
    cell00.rowSpan = 2;
    cell00.colSpan = 1;
    cell00.setImageLocation(imgLocation);
    var cell10 = tableNode.getCell(1, 0);
    cell10.setText(text);
    cell10.setColumnSpan(3);
Node Looks Like:
Lyubo
MindFusion team
Reply #5 - Oct 1st, 2015 at 10:45am
You can override the TableNode's updateCanvasElements method and adjust the image dimensions like this:
Code (Javascript)
var TableNode = MindFusion.Diagramming.TableNode;
var updateCanvasElementsOriginal = TableNode.prototype.updateCanvasElements;
TableNode.prototype.updateCanvasElements = function () {
    updateCanvasElementsOriginal.apply(this);
    var image = this.getCell(0, 0).image;
    var padding = 1; // Adjust this value to the desired padding size
    image.bounds.y += padding;
    image.bounds.height -= padding;
Lyubo
Santosh
Reply #6 - Oct 1st, 2015 at 11:23am
Thanks Lyubo..that works!  Smiley
