Normal Topic Setting more shapes in diagram (Read 1986 times)
Silvia88
Aug 31st, 2015 at 4:23pm
Is it possible to set more than one shape when touching the diagram? I want to draw both rectangle and rhombus but touching the screen it draws a rectangle and then only rhombus while I want to draw rectangles and rhombus according to the user's needs.
Re: Setting more shapes in diagram
Reply #1 - Sep 1st, 2015 at 11:43am
Following discussion from previous thread, here's a method to convert free-drawings to some set of standard shapes, however using a custom class instead of unconnected links:
diagramView.setBehavior(Behavior.Custom);
diagramView.setCustomNodeType(FreeDrawTool.class);
diagram.addDiagramListener(new DiagramAdapter()
	@Override
	public void nodeCreated(NodeEvent e)
		DiagramNode node = e.getNode();
		if (node instanceof FreeDrawTool)
			FreeDrawTool freeDraw = (FreeDrawTool)node;
			ShapeNode replacement = freeDraw.standardShapeReplacement(
				new Shape[]
					Shape.fromId("Rectangle"),
					Shape.fromId("Decision")
			if (replacement != null)
				diagram.getNodes().remove(freeDraw);
				diagram.getNodes().add(replacement);
				diagramView.cancelDrag();
			else
				// replace with default shape or leave free-drawing?
class FreeDrawTool extends DiagramNode
	ArrayList<PointF> points = new ArrayList<PointF>();
	@Override
	public void draw(Canvas g, RenderOptions options)
		Paint paint = new Paint();
		paint.setStyle(Paint.Style.STROKE);
		paint.setColor(android.graphics.Color.BLACK);
		paint.setStrokeWidth(1);
		for (int p = 0; p < points.size() - 1; p++)
			PointF point1 = points.get(p);
			PointF point2 = points.get(p + 1);
			g.drawLine(point1.x,  point1.y,  point2.x,  point2.y, paint);
	@Override
	protected void drawShadow(Canvas g, RenderOptions options)
	@Override
	protected void startCreate(PointF org)
		super.startCreate(org);
		points.add(org);
	@Override
	protected void updateCreate(PointF current)
		super.updateCreate(current);
		points.add(current);
	@Override
	protected boolean allowCreate(PointF current, InteractionState ist)
		return true;
	ShapeNode standardShapeReplacement(Shape[] shapes)
		RectF bounds = calcBounds();
		Shape bestShape = null;
		double bestDeviation = Double.MAX_VALUE;
		final double maxDeviation = 20;
		ShapeNode testNode = new ShapeNode();
		testNode.setBounds(bounds);
		for (Shape shape : shapes)
			testNode.setShape(shape);
			double deviation = 0;
			for (PointF point : points)
				PointF nearest = testNode.getNearestBorderPoint(point);
				deviation += Utilities.distance(point,  nearest);
			deviation /= points.size();
			if (deviation < bestDeviation)
				bestShape = shape;
				bestDeviation = deviation;
		testNode.setShape(bestShape);
		return bestDeviation < maxDeviation ? testNode : null;
	RectF calcBounds()
		PointF pt1 = points.get(0);
		PointF pt2 = points.get(points.size()-1);
		float l = Math.min(pt1.x, pt2.x);
		float r = Math.max(pt1.x, pt2.x);
		float t = Math.min(pt1.y, pt2.y);
		float b = Math.max(pt1.y, pt2.y);
		for (int i = 1; i < points.size() - 1; ++i)
			l = Math.min(l, points.get(i).x);
			t = Math.min(t, points.get(i).y);
			r = Math.max(r, points.get(i).x);
			b = Math.max(b, points.get(i).y);
		return new RectF(l, t, r, b);
It looks cute but gets tiresome if you have to draw a lot; I think users will prefer selecting a default shape and drawing with single swipe instead of having to trace shape outlines.
