Normal Topic Link shape (Read 5672 times)
Silvia88
Link shape
Sep 1st, 2015 at 8:28am
is it possible to change the shape of links? I would like to have links without the arrow, simply made up of a line.
Re: Link shape
Reply #1 - Sep 1st, 2015 at 8:59am
Call link.setHeadShape(ArrowHeads.None) for individual links, or diagram.setLinkHeadShape(...) to set default value for all new links.
Silvia88
Re: Link shape
Reply #2 - Sep 1st, 2015 at 9:32am
Thank you very much, it works.
Is it possible to have also a double link, I mean a link made up of 2 lines?
Re: Link shape
Reply #3 - Sep 1st, 2015 at 9:57am
It's possible using custom-drawing:
diagram.addDiagramListener(new DiagramAdapter()
	@Override
	public void linkCreated(LinkEvent e)
		DiagramLink link = e.getLink();
		link.setCustomDraw(CustomDraw.Additional);
		link.setPen(new Pen(2, Color.red));
	@Override
	public void drawLink(DrawLinkEvent e)
		// draw using a thinner stroke in different color
		link.setCustomDraw(CustomDraw.None);
		link.setPen(new Pen(1, Color.white));
		link.draw(e.getGraphics(), diagram.getRenderOptions());
		// restore default stroke
You might as well set CustomDraw = Full and draw using Android's low-level graphics API instead of calling link.draw for a second time.
Silvia88
Re: Link shape
Reply #4 - Sep 1st, 2015 at 10:22am
Ok, thank you very much...
Is it possible to create a link between a node and already existing link?
Re: Link shape
Reply #5 - Sep 1st, 2015 at 10:53am
Links can only point to nodes. You can simulate link-to-link connection by attaching a small node to the existing link to serve as second link's target, using node.attachTo(link) method.
Silvia88
Re: Link shape
Reply #6 - Sep 1st, 2015 at 11:16am
Ok, thank you very much, i'll try  Smiley
Silvia88
Re: Link shape
Reply #7 - Sep 1st, 2015 at 3:32pm
Is it possbile to remove a link by code?
Re: Link shape
Reply #8 - Sep 1st, 2015 at 4:09pm
Call diagram.getLinks().remove(link);
Silvia88
Re: Link shape
Reply #9 - Sep 1st, 2015 at 4:53pm
ok, thank you very much  Smiley
