Normal Topic DiagramItem (Read 5598 times)
Silvia88
DiagramItem
Sep 7th, 2015 at 12:12pm
Is there a way to distinguish if the added item is a node or a link, in the method ItemAdded?
Re: DiagramItem
Reply #1 - Sep 7th, 2015 at 12:23pm
You could use the instanceof operator:
@Override
public void itemAdded(ItemEvent e)
	if (e.getItem() instanceof DiagramNode)
Silvia88
Re: DiagramItem
Reply #2 - Sep 7th, 2015 at 1:38pm
Ok, thank you..
Is there a way to take the coordinate of the start point of a link?
Re: DiagramItem
Reply #3 - Sep 7th, 2015 at 1:46pm
Try this:
PointList linkPoints = link.getControlPoints();
PointF startPoint = linkPoints.get(0);
Silvia88
Re: DiagramItem
Reply #4 - Sep 7th, 2015 at 2:11pm
Ok, thank you...
Is there a way to decide the length of a link? Or a way to move a node i.e. give other coordinates to a node?
Re: DiagramItem
Reply #5 - Sep 7th, 2015 at 2:55pm
You can find link's length by calling its getLength() method; move a node by calling moveTo or setBounds method.
Silvia88
Re: DiagramItem
Reply #6 - Sep 7th, 2015 at 3:35pm
ok, thank you.
