Normal Topic Disable Mouse events (Read 4329 times)
RJ
Sep 23rd, 2015 at 5:20pm
I would like to disable mouse events on the diagram and be able to drag/move the nodes by clicking on them and edit text be double clicking on the nodes.
I tried the Event handling and set the Diagram Behavior to nothing, but moving the node doesnt work with Click event handler.
Here is the code for reference
Code (Javascript)
diagram = AbstractionLayer.createControl(Diagram, null, null, null, $("#diagram")[0]);
      diagram.setCustomNodeType(OrgChartNode);
      diagram.setBehavior(Behavior.SelectOnly);
      // enable undo/redo support
      diagram.setUndoEnabled(true);
      diagram.addEventListener(Events.nodeCreated, onNodeCreated);
      diagram.addEventListener(Events.linkCreated, onLinkCreated);
      diagram.addEventListener(Events.nodeDoubleClicked, onNodeDoubleClicked);
      diagram.addEventListener(Events.nodeClicked, onNodeClicked);
function onNodeCreated(sender, args) {
    var node = args.getNode();
    //node.setHandlesStyle(MindFusion.Diagramming.HandlesStyle.MoveOnly);
    // let user enter text immediately
    //diagram.beginEdit(node);
  function onNodeClicked(sender, args) {
//diagram.handleBrush = '#4488CC';
    //node.setSelected(true);
    //diagram.setBehavior(Behavior.Pan);
    //node.setEnabledHandles(MindFusion.Diagramming.AdjustmentHandles.Move);
  function onNodeDoubleClicked(sender, args) {
Could you please help.
Raji
Re: Disable Mouse events
Reply #1 - Sep 23rd, 2015 at 5:25pm
If you mean you want to disable drawing new nodes on the canvas but only allow users to move existing ones, set Behavior to Modify instead of SelectOnly.
RJ
Reply #2 - Sep 23rd, 2015 at 5:37pm
That did the trick. Now I want to able to draw links after user clicks on a button and starts clicking on the node - but when i click on the node it only moves now and doesnt let me draw a link.
Raji
Reply #3 - Sep 23rd, 2015 at 5:48pm
try calling diagram.setBehavior(Behavior.DrawLinks) from that button's click handler.
RJ
Reply #4 - Sep 23rd, 2015 at 6:18pm
That is what i currently do. But it is very difficult to draw the link. Should i remove all the handleStyles on the nodes before i enable the DrawLinks Behavior?
Reply #5 - Sep 23rd, 2015 at 7:40pm
It could be difficult for smaller nodes if they are selected, as modification handles are hit-tested with higher priority than draw-link gesture then. You could clear the selection state of nodes before entering draw-links mode, or try a different HandlesStyle (DiagramNode.setHandlesStyle method).
