Normal Topic The diagram is initially trimmed (Read 4236 times)
Santosh
Sep 28th, 2015 at 11:01am
On load of the diagram,
1. The expand(+) button, gets cut marginally. Can we increase the canvas width to adjust this marginally somehow? Or, any other fix?
2. The nodes overlap. Specially the (+) sign is overlapped by another node.
3. There is a small bar above the tabular node.
I added Mindfusion.Common.js, but still dint fix the problem.
Re: The diagram is initially trimmed
Reply #1 - Sep 28th, 2015 at 12:20pm
The +/- icon's is not considered part of node's bounds by layout calculations. Its right side is at 5 mm distance from node's right border, so:
1. When calling resizeToFitItems after layout, pass a larger margin argument than 5 (if using default millimeter unit).
2. Set treeLayout.nodeDistance to a larger value too.
I suppose 3 shows the divider line between table's caption-bar and cell area, with CaptionHeight set to 0 and Shape set to RoundedRectangle. We'll fix it for official release to not draw divider when CaptionHeight is 0.
Santosh
Reply #2 - Sep 28th, 2015 at 12:39pm
Thanks Stoyo. 1 & 2 are fixed, and working great.
Any temporary solution for 3, till we get the next official release?
Reply #3 - Sep 28th, 2015 at 1:20pm
Try this:
var TableNode = MindFusion.Diagramming.TableNode;
var updateCanvasElementsOriginal = TableNode.prototype.updateCanvasElements;
TableNode.prototype.updateCanvasElements = function ()
    updateCanvasElementsOriginal.apply(this);
    var content = this.graphicsContainer.content;
    // look for divider Line object
    var index = -1;
    for (var i = 0; i < content.length; i++)
        var contentElement = content[i];
        if (MindFusion.Drawing.Line.isInstanceOfType(contentElement))
            index = i;
            break;
    // remove if found
    if (index > -1)
        content.splice(index, 1);
Santosh
Reply #4 - Sep 29th, 2015 at 6:11am
The above code gives error:
Code (Javascript)
Uncaught TypeError: MindFusion.Drawing.Line.isInstanceOfType is not a function
I tried MindFusion.Drawing.Line.isPrototypeOf(contentElement), but did the line did not get removed.
Reply #5 - Sep 29th, 2015 at 8:35am
That code was using MS Ajax library. Replace it with this instead:
if (MindFusion.AbstractionLayer.isInstanceOfType(
    MindFusion.Drawing.Line, contentElement))
    index = i;
    break;
Santosh
Reply #6 - Sep 29th, 2015 at 9:18am
that worked! thanks Stoyo  Smiley
