Normal Topic Change mouse pointer while dragging (Read 3112 times)
RJ
Sep 29th, 2015 at 4:51pm
Is there a way to change the mouse icon in the node list view while dragging a shapenode and dropping it in the diagram - i want the mouse to have the icon it is dragging from the nodelistview to the diagram canvas.
Raji
Re: Change mouse pointer while dragging
Reply #1 - Sep 29th, 2015 at 6:03pm
The NodeListView already shows the dragged shape as mouse pointer, do you need it shown in a different format?
RJ
Reply #2 - Sep 29th, 2015 at 6:15pm
I dont see it my NodeListView. Should i turn on some property?
Raji
RJ
Reply #3 - Sep 29th, 2015 at 10:46pm
I found what the issue could be. I have three NodelistView in the Accordian. The mouse pointer shows the node while dragging only on the last nodelistview. Is there a way to make it work in the rest as well? Also how to make it work on Custom Nodes?
Raji
« Last Edit: Sep 30th, 2015 at 1:39am by RJ »
Lyubo
MindFusion team
Reply #4 - Sep 30th, 2015 at 9:02am
This appears to be a bug. We will include a fix for the next release.
For custom nodes in a NodeListView you can check out the Tutorial4 example, supplied with JsDiagram. Basically you need to provide a clone method override in your custom node implementation.
Lyubo
