Normal Topic The diagram overflows outside canvas (Read 2758 times)
Santosh
Oct 5th, 2015 at 6:10am
On expanding nodes, the diagram overflows canvas, and some of the diagram is not visible.
Diagram 1 below represents the diagram on page load
Diagram 2 represents the diagram when all nodes are expanded
In Diagram 2, the nodes overflow the canvas
Re: The diagram overflows outside canvas
Reply #1 - Oct 5th, 2015 at 8:57am
Try resizing it from treeExpanded event handler:
diagram.addEventListener(Events.treeExpanded, onTreeExpanded);
function onTreeExpanded(sender, args)
	var diagram = sender;
	var margin = 10;
	var contentRect = diagram.getContentBounds();
	var diagRect = diagram.getBounds();
	if (contentRect.bottom() > diagRect.bottom() ||
		contentRect.right() > diagRect.right())
		diagram.setBounds(
			diagRect.union(contentRect.inflate(margin)));
Santosh
Reply #2 - Oct 5th, 2015 at 9:31am
Hi Stoyo,
The above code creates some overlaping between the nodes
Reply #3 - Oct 5th, 2015 at 9:37am
The above code doesn't touch nodes at all. Perhaps you already had a treeExpanded handler that applies TreeLayout and that new method replaces it? In such case copy only the function body to your existing handler, appending to TreeLayout code.
Santosh
Reply #4 - Oct 5th, 2015 at 10:01am
Thanks Stoyo...that helped Smiley
