Normal Topic ShapeNode list (Read 5299 times)
Silvia88
ShapeNode list
Oct 6th, 2015 at 10:48am
I have a list of ShapeNode and I want to order it according to the left bounds of the nodes, I did in this way, but it doesn't work:
ShapeNode temp = null;
                    for(int z = 0; z < e.getPrevoiusNodes().size(); z++){
                        for(int i = e.getPrevoiusNodes().size() - 1; i >= z; i--){
                            if(e.getPrevoiusNodes().get(i).getBounds().left >= e.getPrevoiusNodes().get(i+1).getBounds().left){
                                temp = e.getPrevoiusNodes().get(i);
                                e.getPrevoiusNodes().get(i)= e.getPrevoiusNodes().get(i+1);
                                e.getPrevoiusNodes().get(i+1) = temp;
Re: ShapeNode list
Reply #1 - Oct 6th, 2015 at 12:17pm
You should call getPrevoiusNodes' set() method instead of assigning to get()'s result, which is just a temporary value in the function's stack.
Silvia88
Re: ShapeNode list
Reply #2 - Oct 6th, 2015 at 12:25pm
Sorry but it doesn't work the method set, maybe I was wrong, could you give me an example?
Re: ShapeNode list
Reply #3 - Oct 6th, 2015 at 12:39pm
I don't know what your getPrevoiusNodes method returns. If it's a standard Java List<> container, better call java.util.Collections.sort method on it instead of trying to sort yourself. The getBounds().left comparison from your code should go into the implementation of Comparator object you pass to sort().
Silvia88
Re: ShapeNode list
Reply #4 - Oct 6th, 2015 at 12:56pm
Yes, it's a List of ShapeNode, but what can I pass to comparator? to get the bounds I need a ShapeNode but here I have a list of ShapeNode
Silvia88
Re: ShapeNode list
Reply #5 - Oct 6th, 2015 at 1:11pm
Sorry, I solved, I made a cast to ShapeNode in the comparator and it works
