Normal Topic Gantt Chart (Read 5111 times)
RJ
Gantt Chart
Oct 6th, 2015 at 4:41pm
I want to create a gantt chart looking like the picture in the attachment. Will i need two lanegrids? If so can i do it in the same diagram? Or can i do it using a single lane grid. I need to know the best way to achieve this.
RJ
Re: Gantt Chart
Reply #1 - Oct 6th, 2015 at 7:07pm
You can create only one grid in a diagram, but if you set the fill and border colors of 7th column to be same as diagram's background, it will look split in two as in the image. However if you need the right grid to scroll independently from left one (as is often the case with Gantt charts), you will need a second diagram.
RJ
Re: Gantt Chart
Reply #2 - Oct 7th, 2015 at 2:42pm
Thanks Stoyan. I thik i'll do it two grids. Is it possible to have two grids in the same canvas or do i need separate canvas for each grid?
RJ
Re: Gantt Chart
Reply #3 - Oct 7th, 2015 at 3:47pm
There's only one built-in lane grid per diagram instance, so you'd need two diagrams backed by two <canvas> elements. Alternatively, use locked TableNodes in diagram background to draw as many grids as you'd like to.
RJ
Re: Gantt Chart
Reply #4 - Oct 9th, 2015 at 4:08pm
Thanks Stoyan. I was able to achieve this with two diagrams. I have one question - how to increase the width of individual columns without increasing the height inside the Grid.
I tried
grid.setMinHeaderSize(30);
But it increases both width and height.
Raji
RJ
Re: Gantt Chart
Reply #5 - Oct 9th, 2015 at 4:40pm
Also how to enable text editing in individual cells in the grid?
Raji
Re: Gantt Chart
Reply #6 - Oct 9th, 2015 at 5:29pm
Call Header.setWidth() method for the columns headers, i.e. the ones you pass to grid.addColumnHeader() method to create columns.
Re: Gantt Chart
Reply #7 - Oct 12th, 2015 at 2:16pm
The lane-grid was used mostly for background graphics and did not support text editing. We've now implemented this here for upcoming release:
https://mindfusion.eu/_beta/jsdiag_edit_grid.zip
To enable editing cells' text, call diagram.getLaneGrid().setAllowInplaceEdit(true) and you will be able to enter text after double-click on a cell.
If you will need more data grid -like features such as sorting, selecting rows, filtering, etc, consider using an actual grid control as left part of the Gantt view.
