Normal Topic Copy/Paste/Cut Undo-Redo pattern (Read 5694 times)
Marco Pessina
Dec 3rd, 2015 at 1:13pm
i'm quite new to mindfusion diagramming component, and I'm migrating from a Winform solution to a web based application a tool to create and design workflow.
Does anyone has some suggest on how to implement copy/paste/cut and undo-redo pattern in web platform?
In my winform solution was anough handling DV1.KeyDown event  with this code
        If e.KeyCode = Key.C AndAlso
               e.Control = True Then
            ' paste with offset
            m_pasteDX = 10
            m_pasteDY = 10
            ' True specifies that data should stay in the clipboard
            ' after the application exits
            DV1.CopyToClipboard(True)
        ElseIf e.KeyCode = Key.X AndAlso e.Control = True Then
            m_pasteDX = 0
            m_pasteDY = 0
            DV1.CutToClipboard(True)
        ElseIf e.KeyCode = Key.V AndAlso e.Control = True Then
            ' Code for Paste Action
            ' paste with offset; allow unconnected arrows
            DV1.PasteFromClipboard(m_pasteDX, m_pasteDY, True)
            ' next time paste with bigger offset
            m_pasteDX += 10
            m_pasteDY += 10
        ElseIf e.KeyCode = Key.Z AndAlso e.Control = True Then
            dg.UndoManager.Undo()
        ElseIf e.KeyCode = Key.Y AndAlso e.Control = True Then
            dg.UndoManager.Redo()
        End If
Thans in advance.
Marco Pessina
Re: Copy/Paste/Cut Undo-Redo pattern
Reply #1 - Dec 3rd, 2015 at 1:33pm
Tutorial 7 shows both clipboard and undo methods. You could also check the Keyboard sample project, which shows how to handle keydown events:
function onKeyDown(e) {
    var diagram = MindFusion.Diagramming.Diagram.find('diagramView1');
    //copy selected items
    if (e.keyCode == 67 && e.ctrlKey) {
        diagram.copyToClipboard();
    //paste selected items
    if (e.keyCode == 86 && e.ctrlKey) {
        diagram.pasteFromClipboard(5, 5);
Marco Pessina
Reply #2 - Jan 13th, 2016 at 7:56am
Hi Stoyan,
I've implemented the pattern you suggest me and everything seems working, except one things.
I've handled diagram.onNodeCreatedScript event to set items.id property (as an identity on database table),
and using pasteFromClipboard it doesn't fire this event so it duplicates ids on items. Is there a sort of itempasted event?
Thanks in advance.
Regards
Marco Pessina
Reply #3 - Jan 13th, 2016 at 11:10am
Hi Marco,
There are NodePasted and LinkPasted events in our desktop components. We'll try to implement them in ASP.NET MVC version in next couple of days. Until they are available, you could loop over selected items and update id values after calling pasteFromClipboard method, as it replaces old selection with the pasted items.
Reply #4 - Jan 20th, 2016 at 10:02am
NodePasted and LinkPasted events are now available in this release:
http://mindfusion.eu/Forum/YaBB.pl?num=1453227455
