Normal Topic NodesExpandable not working with ControlNode (Read 2946 times)
SStone
Dec 4th, 2015 at 3:09am
I'm new and testing features, but I can't seem to make "NodesExpandable" feature work with ControlNodes.
I set "Expandable" to true on the node but never see the expand/collapse button.  I don't see in the docs where it shouldn't work. I tried both empty ControlNode and one with a panel assigned to the control. No luck.
Re: NodesExpandable not working with ControlNode
Reply #1 - Dec 4th, 2015 at 10:04am
It should work with this build:
https://mindfusion.eu/_temp/ctrlnodes.zip
Try using CompositeNodes instead anyway, unless you need to show some complex controls. We've created them as replacement of ControlNodes and they integrate much better with other diagram features, such as hit-testing, Z order and printing.
SStone
Reply #2 - Dec 4th, 2015 at 5:29pm
I don't see how to add a "Control" class to the "CompositeNode"
The ControlNode had a "Control" property.
I'm guessing only your "ComponentBase" classes are allowed in a CompositeNode.
Any way to have a ComponentBase derived class that has a windows handle to place standard controls in??
I've included a image of what I'm trying to do. All seems to work except the Expandable feature. Which is important.
Thanks for all your help.
Reply #3 - Dec 4th, 2015 at 5:35pm
There's no way to do that; ComponentBase-derived objects are used as light-weight alternative of full Control objects and are not intended to open additional window handles as ContolNode-hosted controls do.
It should work with the new build above. Alternatively you could call Expand/Collapse methods from a +/- button inside the hosted control.
