Normal Topic Identifying selected node in TabbedDiagramView (Read 3033 times)
justinp
Dec 11th, 2015 at 6:37pm
How do I get the node object via an event on a DiagramPage that's in a TabbedDiagramView when the node is selected?
Re: Identifying selected node in TabbedDiagramView
Reply #1 - Dec 11th, 2015 at 7:04pm
If you don't need selection handled differently for different pages, handle DiagramDocument.NodeSelected to get the event raised for any page in the document. Handle DiagramPage.NodeSelected if you need it only for some distinct page.
justinp
Reply #2 - Dec 13th, 2015 at 8:53pm
Thanks, but I can't seem to get the event to trigger. Could you post a code snippet for the event handler please?
Reply #3 - Dec 14th, 2015 at 8:44am
Check the sample project here:
https://mindfusion.eu/_samples/TabbedView_NodeSelected.zip
The event handlers just add a string to ListBox control:
tabbedDiagramView.Document.NodeSelected +=
	(s, e) => lbLog.Items.Add("DiagramDocument.NodeSelected");
tabbedDiagramView.Document.Pages[0].NodeSelected +=
	(s, e) => lbLog.Items.Add("DiagramPage.NodeSelected");
If you draw and select nodes on first page you should see both messages logged. If you open a second page and select nodes there, the log will show only document's message, unless you also attach handler to new DiagramPages (e.g. from TabbedDiagramView.PageAdded event).
If you have already attached handlers but can't get them to raise, check if your project doesn't replace the DiagramDocument/Page objects with new instances at some point without attaching handlers to them.
