Hot Topic (More than 10 Replies) Many items, performance lack (Read 14617 times)
SGS Software
Jan 15th, 2016 at 8:02am
unfortunately I have a problem.
The scenario is about 25/30 resources, all the full year and
60 visible days. The software that I am developing is an hotel room
planner so there are so many items to display "per page".
I wrote "per page" because the loading is paginated, when I move
left/right/up/down I load only the visible resources and items.
By the way, I noticed that the permormance is very poor to rebuild the schedule (I used BeginInit and EndInit, but nothing changes) and the mouse interaction become so slow!
The query to pick up the results run in less than a second but the scheduler
takes 2/3 seconds to clear and rebuild...Any advice to speed up?
I populate data asynchronously so the loop to add items is the following:
VB
Dim _items As New ItemCollection
Dim counter As Integer = 1
For Each row In _dtItems.Rows
	If IsDBNull(row!From) = False Then
		Dim o As New Appointment()
		o.Id = counter
		o.HeaderText = row!Name
		o.StartTime = row!From
		o.EndTime = row!To
		o.Resources.Add(.Schedule.Resources(row!ResourceId))
		o.AllowMove = False
		_items.Add(o)
	End If
	counter = counter + 1
Next
.Schedule.Items.AddRange(_items)
Thank you.
Re: Many items, performance lack
Reply #1 - Jan 15th, 2016 at 11:01am
We will look into it. Are you still using the Resource view? What is the approximate total number of items in the view at one time?
SGS Software
Reply #2 - Jan 15th, 2016 at 11:23am
Meppy wrote on Jan 15th, 2016 at 11:01am:
Yes, It's the ResourceView mode...building the scheduler by firing some buttons. right and left change the HScrollPos value, up and down are used to perform the resources pagination.
I attach a common scenario.
Thank you.
Reply #3 - Jan 15th, 2016 at 12:24pm
Do you clear the Schedule.Items collection before adding the new items?
SGS Software
Reply #4 - Jan 15th, 2016 at 2:07pm
Meppy wrote on Jan 15th, 2016 at 12:24pm:
Yes, befor starting the data feed loop I run this:
.Resources.Clear()
.Schedule.Resources.Clear()
.Schedule.Items.Clear()
I tested with and without .BeginInit and .EndInit
but the result it's the same
Reply #5 - Jan 19th, 2016 at 10:17am
We made some performance improvements to the Resource view. The new version of the assemblies can be downloaded from the link below:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.6.2.zip
Please, let me know if there are any problems with this update.
SGS Software
Reply #6 - Jan 19th, 2016 at 11:35am
Meppy wrote on Jan 19th, 2016 at 10:17am:
Thank you. I will test and let you know!
Do you advice me to perform BeginInit and EndInit?
If affermative, should I perform it while deleting or while populating?
Reply #7 - Jan 19th, 2016 at 11:43am
Use BeginInit/EndInit when initializing the control with data or when you perform a batch of modifications (e.g. when deleting many items at once). Regardless, the control should be faster when interacting with the items in a grouped view where only some of the resources are visible.
SGS Software
Reply #8 - Jan 20th, 2016 at 7:49am
Meppy wrote on Jan 19th, 2016 at 11:43am:
Ok.
Tested, but honestly not so much better than before..
Reply #9 - Jan 20th, 2016 at 8:24am
Approximately how many items are visible at a time in the view? Also, how do you perform the resource pagination?
Reply #10 - Jan 20th, 2016 at 8:31am
Locally I am running a test with 5000 resources with 100 items each (a total of 500k items) where only 30 resources are visible at a time and the control performs decently.
SGS Software
Reply #11 - Jan 20th, 2016 at 9:09am
Meppy wrote on Jan 20th, 2016 at 8:31am:
Can you provide me the example?
Maybe I am wrong is something that I can't currently figure out...
Reply #12 - Jan 20th, 2016 at 10:53am
Reply #13 - Jan 22nd, 2016 at 8:48am
We made further improvements to the loading and displaying speed of the schedule. You can download the test application (in C#) and the updated assemblies from the following link:
https://mindfusion.eu/_samples/_sample_AdvancedItemDrawing5.zip
The sample now loads only the visible resources and items for each page. Scrolling up/down clears the schedule completely and reloads the newly appeared resources/items. In addition, the following settings have been changed to improve performance:
  • The shadows have been turned off.
  • The collisions have been turned off (ResourceViewSettings.EnableCollisions). I noticed that none of your items collide so you may as well turn this setting off.
The schedule now takes 0.04s to scroll to a new page.
Let me know if this helps.
SGS Software
Reply #14 - Jan 25th, 2016 at 7:38am
Meppy wrote on Jan 22nd, 2016 at 8:48am:
Hi, it works better!
As I can see "Locations" were used instead of "Resources".
Is there a specific reason for this?
