Normal Topic Anchor Point with custom size (Read 2816 times)
RickSalut
Feb 17th, 2016 at 3:26pm
in my diagrams, I use a lot of different anchor points in order to allow arrows to be hooked to my shapes from multiple angles.
Some users find it difficult sometimes to drag an arrow to some of these (small) anchors and are asking if it would be possible to make their hooking diameter (when the mouse pointer becomes a hand) a little bigger.
Is it?
Thank's a lot.
Online
Re: Anchor Point with custom size
Reply #1 - Feb 17th, 2016 at 4:47pm
Hello Rick,
If you set AutoSnapToNode property of links to true they will connect to anchor points from as far away as diagram's AutoSnapDistance value.
I'm not sure if that's done by the diagram control. Please verify if your application isn't handling validation events like linkCreating to only allow creation near anchor point - then you'd be able to change diameter from event handler's code.
