Normal Topic Get the area bounds based on node id (Read 3146 times)
Shah
Feb 23rd, 2016 at 10:44am
Is it possible to get node bounds based on specified node id? Is there any vb.net sample i can refer?
Thanks.
Re: Get the area bounds based on node id
Reply #1 - Feb 23rd, 2016 at 10:47am
If you have assigned an identifier to DiagramNode.Id property, you can find the node by calling Diagram.FindNodeById() method. The node's boundaries are returned by DiagramNode.Bounds property.
Shah
Reply #2 - Feb 23rd, 2016 at 10:49am
Any sample code i can refer to?
Thanks.
Reply #3 - Feb 23rd, 2016 at 11:27am
Here's a code snippet that returns optional RectangleF value if the specified node exists -
Function NodeBoundsFromId(ByVal id As Object) As RectangleF?
	Dim node As DiagramNode = Diagram1.FindNodeById(id)
	If node Is Nothing Then Return Nothing
	Return node.Bounds
End Function
Diagram1.Factory.CreateShapeNode(10, 10, 10, 10).Id = "1"
Dim r As RectangleF? = NodeBoundsFromId("1")
If r IsNot Nothing Then Debug.WriteLine(r)
Shah
Reply #4 - Feb 23rd, 2016 at 11:49am
Thanks for the sample. It's work.
Shah
