Normal Topic Anchorpoint in Center automatically selected (Read 3792 times)
Brownson
Mar 26th, 2016 at 1:33pm
I have a problem with anchor points. When the user select an anchorpoint to start an Link, the centered anchorpoint is automatically chosen - is there any way to get around this?
After the link is created, the starting point of the link can be moved to the correct position.
I have already tried to disabled DynamicLinks and to adapt the option RoutingOptions.Anchoring, but the starting point is still moved to the center:
Brownson
Re: Anchorpoint in Center automatically selected
Reply #1 - Mar 26th, 2016 at 2:20pm
Is that a TableNode with RowAnchorPattern set?
Brownson
Reply #2 - Mar 26th, 2016 at 2:40pm
Yes, it's a Tablenode with Anchorpattern assigned for each of the rows
Reply #3 - Mar 28th, 2016 at 7:48am
This looks like a bug that was fixed in 6.3.4 release. Try latest version if you are now using 6.3.3 or older one.
Brownson
Reply #4 - Mar 29th, 2016 at 11:23am
Thanks for your reply, I was already using version 6.3.4.
I have now tried to reproduce the problem in one of the demo project and I was able to reproduce it in the "Demo" project but not in the "Entities" project.
After some experiments I identified the problem by the following line:
   this.diagramView.Behavior = Behavior.DrawLinks;
Reply #5 - Mar 29th, 2016 at 12:15pm
This build should fix the DrawLinks behavior too -
https://mindfusion.eu/_temp/rowap_drawlinks.zip
Brownson
Reply #6 - Mar 29th, 2016 at 7:39pm
Thanks for your fast response, the build has fixed the problem Smiley
