Normal Topic Save and Load from XML (Read 2268 times)
Shah
Apr 27th, 2016 at 8:29am
Hi again,
Actually i'm kind of blur on xml part in diagramming. How to save all diagram information inside xml and load the diagram with this kind information. Really blur on this part. Any sample code that i can refer to.
Thanks in advance. Smiley Smiley
Shah
Shah
Re: Save and Load from XML
Reply #1 - Apr 27th, 2016 at 8:42am
Nvermind. Already configure this thing..is it possible to save the xml details inside database instead of local directory.
Thanks.
Shah
Reply #2 - Apr 27th, 2016 at 9:02am
You could call Diagram's SaveToString method and store the string inside a database field. Later load the diagram using LoadFromString.
