Normal Topic Scaling ShapeNode Images In ImageMap Mode (Read 4407 times)
Eric Johnson
May 9th, 2016 at 12:04pm
We are using an older version of NetDiagram (3.1) and would simply like to switch from JavaApplet mode to ImageMap mode. For the most part, everything works fine in ImageMap mode for us except when there is an image attached to a ShapeNode - the image doesn't scale when you change the ZoomFactor. Is this just not possible with ImageMap mode? Or, is it because the version of NetDiagram we are using doesn't support it? I've attached images at 100% and 50% zoom to illustrate the issue.
Re: Scaling ShapeNode Images In ImageMap Mode
Reply #1 - May 9th, 2016 at 7:20pm
Try assigning instance of this class to DiagramView.Diagram as a work-around -
// work-around for non-stretching ImageAlign values
class MyDiagram : Diagram
	public override void Draw(
		IGraphics graphics,
		RenderOptions options,
		RectangleF clipRect,
		bool noModifiedItems)
		options.Scale = 100 * graphics.Transform.Elements[0];
		base.Draw(graphics, options, clipRect, noModifiedItems);
Eric Johnson
Reply #2 - May 10th, 2016 at 5:29pm
Slavcho,
Thanks for your help with this, but unless I'm missing something here the DiagramView.Diagram property is read-only. How can the override you've provided be applied in that case?
-Eric
Reply #3 - May 11th, 2016 at 8:31am
The oldest version I have is 5.0 (it's already 4-5 years old) and it lets me assign to the Diagram property. I'll try to find 3.1 in our archives to see if you can set the diagram in some way there.
Reply #4 - May 12th, 2016 at 1:41pm
We've found 3.1 code and fixed this there, please find new build on the personal messages page. We've also made Diagram settable, just in case. This is a one-time service, if you expect you'll need more help for the switch please renew your maintenance. That will also get you latest version and you could switch to the newer HTML5 Canvas mode then.
Eric Johnson
Reply #5 - May 12th, 2016 at 6:15pm
Slavcho,
That did the trick - thank you. This goes well beyond any customer support I've seen before and I will remember it.
-Eric
