Hot Topic (More than 10 Replies) MindFusion JS diagram version 2.1 “Node Clicked Event” on the mobile devices not firing (Read 11495 times)
Re: MindFusion JS diagram version 2.1 “Node Clicked Event” on the mobile devices not firing
Reply #15 - Jun 9th, 2016 at 8:39am
FYI we have uploaded a patched 2.6 build at http://clientsarea.eu/ , you shouldn't need the above work-around with it.
Ranadheer Reddy
Reply #16 - Jun 9th, 2016 at 8:57am
Thanks for the reply.
I have tried using JQuery mode in my project, but still the issue exists. Sad
In the below way i have set the JQuery mode in my html.
Code (HTML)
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
	<title>MindFusion.Diagramming for JavaScript: Tutorial 1</title>
</head>
<body>
    <!-- The Diagram component is bound to the canvas element below -->
    <div style="width:100%; height:1100px; border: 5px solid; border-color: green; overflow: auto;">
        <canvas id="diagram" style="width:1800px; height:800px; cursor: default;">
            This page requires a browser that supports HTML 5 Canvas element.
        </canvas>
    </div>
    <script type="text/javascript">
        MindFusionImpl = "JQuery";
    </script>
    <script src="jquery-2.1.4.min.js" type="text/javascript"></script>
	<script src="MicrosoftAjax.js" type="text/javascript"></script>
	<script src="MindFusion.Diagramming.js" type="text/javascript"></script>
	<script src="Tutorial1.js" type="text/javascript"></script>
</body>
</html
I have also Overrided the emulateMouse in my js file as suggested below
Code (Javascript)
Diagram.prototype.emulateMouse = function (e)
    var touches = e.touches;
    var mouseEvent =
        button: 0,
        clientX: touches[0].clientX,
        clientY: touches[0].clientY
    return mouseEvent;
Do i need to do any more anychanges to my code..??
Please find attached Project where i have made Jquery mode as default.
Note: We are Using Diagram of 2.1 version
Ranadheer
MindFusionSampleProject__3_.zip (Attachment deleted)
Reply #17 - Jun 9th, 2016 at 10:34am
There's some scale applied to the canvas because of the style.width and style.height assignments here -
The component later sets element's width and height properties (*not* through element.style) from its resizetoFitItems method; that stretches the canvas and you see mismatch between actual graphic coordinates we use to draw and what's actually rendered.
Removing those fixes it for me -
<canvas id="diagram" style="cursor: default;">
Reply #18 - Jun 9th, 2016 at 10:53am
Now I see your code still tries to load json using MS Ajax and Array.forEach enumeration but you get a blank canvas. I think jQuery adds its own Array.forEach extension with a different signature and breaks your existing code. Try using ArrayList.forEach instead as in our code from http://mindfusion.eu/_samples/testtouch/Tutorial1.html
It also replaces MS JSON loading code with jQuery equivalent.
« Last Edit: Jun 9th, 2016 at 4:29pm by Slavcho »
Ranadheer Reddy
Reply #19 - Jun 10th, 2016 at 11:59am
So, u meant to say that no where we need to use MS Ajax and we need to use only JQuery mode...??
Ranadheer
Reply #20 - Jun 10th, 2016 at 12:13pm
I guess you can keep using MS Ajax if you want, just fix the Array.forEach error then.
