Normal Topic Diagram not working within iframe (Read 3187 times)
FreakAzoid
Jun 10th, 2016 at 8:55am
If we click on a diagram to expand or collapse items, it works! But it the diagram is within an iframe a security error occurs.
Is it a bug? Is it normal for mindfusion purposes?
I am using Angular2 Beta 15.
Re: Diagram not working within iframe
Reply #1 - Jun 10th, 2016 at 9:07am
This happens because of same-origin security policy of browsers used to prevent XSS attacks, it doesn't seem related to the diagram itself. The error would happen if any script loaded through the IFRAME tries to access main page objects or vice-versa. You will just need to change the IFRAME's source to use the same port as the main page (e.g. 41110 instead of 16405 shown in the stack trace). For more information on same-origin policy see http://stackoverflow.com/questions/25098021/securityerror-blocked-a-frame-with-o...
edit: Only suspicious thing I can see in collapse method (from top of stack trace) is a reference to MindFusion.Collections, which is defined in separate common.js file. So if you need to keep the iframe on a different site, maybe check if the application loads common.js from top-level page and diagramming.js from iframe.
FreakAzoid
Reply #2 - Jun 13th, 2016 at 12:45pm
Thank you for your answer!
The scipts are coming all from port 41110. It's a CDN for all our scripts. In the screenshot you can see that the parent page never loads the mindfusion scripts. Only the iframe loads the MindFusion.Common.js and MindFusion.Diagramming.js.
The site within the iframe should be standalone and should also be hosted in an iframe. Standalone its working.
Still the error occur.
In another browser i can see additional error infos:
Error: Permission denied to access property "expandOnIncoming" in MindFusion.Diagramming.js
Reply #3 - Jun 13th, 2016 at 2:15pm
We have a bug-fix related to that property listed in 2.6 releases notes, please check if latest version fixes the exception for you -
http://mindfusion.eu/Forum/YaBB.pl?num=1464603622
The cross-domain error might be happening if some exception-handling scripts of yours load from a different port, so you might still want to look into that even if latest version fixes the original exception.
FreakAzoid
Reply #4 - Jun 13th, 2016 at 2:27pm
Thank you ver much! The bug fix release fixes the issue! No erros occur by clicking on the diagram.
Gravity
Reply #5 - Oct 7th, 2016 at 11:19am
i think those two lines should fix your iframe issue:
Code (Javascript)
    <meta http-equiv="X-Frame-Options" content="allow" />
    <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE10" />
just in case  you are trying to implement data communication between parent and iframe page just give up
