Normal Topic Access Object Within Node.Tag (Read 5780 times)
Megan1717
Jul 1st, 2016 at 3:54pm
I need to access the object, we'll say of type "Student", from the node's tag on server-side (controller method). Sending the diagram through AJAX to the controller method works fine, and I can manipulate other properties of that diagram's nodes, such as tooltip, without a problem. However, when I try to explicitly cast the node.Tag to Student, I get an internal server error. The node's tag was originally set as an object reference with type "Student." Is there a way to get that data back and be able to work with it? In cases where I just send a node's tag over using AJAX and do some logic, it works fine, but in this case I need to basically send the whole diagram to do my logic.
Many thanks in advance!
Online
Re: Access Object Within Node.Tag
Reply #1 - Jul 1st, 2016 at 5:36pm
I think you must create a JavaScriptConverter class for custom types you assign to Tag, both to make them accessible as JavaScript objects on client side and to preserve them after postback. Here's one of the diagram's converters you could use as a template -
/// <summary>
/// Serializes SizeF instances.
/// </summary>
internal class SizeConverter : JavaScriptConverter
    /// <summary>
    /// SupportedTypes override.
    /// </summary>
    public override IEnumerable<Type> SupportedTypes
        get
            return new List<Type>(new Type[] { typeof(System.Drawing.SizeF) });
    /// <summary>
    /// Deserialize override.
    /// </summary>
    public override object Deserialize(IDictionary<string, object> dictionary, Type type, JavaScriptSerializer serializer)
        System.Drawing.SizeF size = new System.Drawing.SizeF();
        size.Width = ((IConvertible)dictionary["width"]).ToSingle(CultureInfo.InvariantCulture);
        size.Height = ((IConvertible)dictionary["height"]).ToSingle(CultureInfo.InvariantCulture);
        return size;
    /// <summary>
    /// Serialize override.
    /// </summary>
    public override IDictionary<string, object> Serialize(object obj, JavaScriptSerializer serializer)
        IDictionary<string, object> json = new Dictionary<string, object>();
        System.Drawing.SizeF size = (System.Drawing.SizeF)obj;
        json.Add("isEmpty", size.IsEmpty);
        json.Add("width", size.Width);
        json.Add("height", size.Height);
        return json;
You must pass your converters to DiagramView.RegisterConverters methods before serializing to or deserializing from JSON.
Megan1717
Reply #2 - Jul 1st, 2016 at 7:34pm
Thank you for the information and quick response. I did create a converter class that inherits from JavaScriptConverter and added it to the diagram view:
Code (C++)
view.RegisterConverters(new JavaScriptConverter[] { new StudentConverter()});
I'm stuck on what to do in the controller in order to use the converter and create Student objects out of the nodes' Tags. This is what I have so far:
Code (C++)
  public JsonResult SelectedStudent(string json, int num)
            DiagramView view = DiagramView.FromJson(json);
            Diagram diagram = view.Diagram;
            foreach (var node in diagram.Nodes)
                //Only look at Student nodes
                if(node is Student)
                    ShapeNode selectedStudent = (ShapeNode)node;
                    //Node.Tag.Id should represent the student's id
                    if(node.Tag.Id == num)
                        //do stuff
            return Json(new { success = DiagramView.ToJson(view) });
Because I'm getting the number from another 3rd party control, I cannot just send the node. I must match that number to the number in the node's tag.
Thanks again.
Online
Reply #3 - Jul 1st, 2016 at 7:47pm
You should register the converters on same instance that loads or saves JSON, try changing your code to this -
var view = new DiagramView();
view.RegisterConverters(...);
view.LoadFromJson(json);
Later, node will never be student but node.Tag instead, so replace the if(node is Student) check with this -
var student = node.Tag as Student;
if (student != null && student.Id == num)
Megan1717
Reply #4 - Jul 5th, 2016 at 2:35pm
Thanks, again for your advice. So, I spent some time over the weekend looking at JavaScript Converter classes and experimenting with other ways to get the nodes' tags after   sending them through an AJAX call to a controller method. Another thing I found was that even if I just wanted to access a node's tag in the controller method without trying to use it as a specific object type, it comes up null even though I can see the appropriate tag data in the json parameter when debugging. How can I get to a diagram's nodes' tags in the controller method and have them not be null? I am guessing this is related to how Json works.
Thanks in advance for your time and patience.
Online
Reply #5 - Jul 5th, 2016 at 6:57pm
Are you initially setting node.Tag on client side?
Megan1717
Reply #6 - Jul 5th, 2016 at 7:34pm
Node.Tag is set in the view using C#/Razor, because it needs to hold "Student" data. Please correct me if I am wrong, but I cannot set the node.tag in client side to a Student object, since JavaScript won't recognize this object type, right? However, I need to be able to get that Student data back from the tags in a controller method. For instance, if the user clicks a node representing "Bob," I need to be able to access Bob's properties as a student object in the controller method and do whatever magic I need to, if that makes sense.
Thanks for your continued patience.
Online
Reply #7 - Jul 6th, 2016 at 10:17am
That might be the problem - the diagram loads Json sent by these converters by first instantiating JavaScript classes by calling 'new' operator, so you might need a Student class in JavaScript too (similar to how the library defines ShapeNode both as C# and JS classes). Our developer will check if this can be done to work with anonymous objects so you define classes only in C#. We'll upload an example later.
Online
Reply #8 - Jul 7th, 2016 at 7:28am
It turns out it works with anonymous objects, but you must also call the RegisterItemType method so the control knows what .NET object to create from the type field stored in Json -
public JsonResult Test(string json)
   DiagramView view = new DiagramView();
   view.RegisterItemType(typeof(Student), "Student", "", 0);
   view.RegisterConverters(new JavaScriptConverter[] { new StudentConverter() });
   return Json(new { success = view.SaveToJson() });
/// <summary>
/// Serializes Student instances.
/// </summary>
internal class StudentConverter : JavaScriptConverter
 /// <summary>
 /// </summary>
  get
   return new List<Type>(new Type[] { typeof(Student), typeof(IDictionary<string, object>) });
 /// <summary>
 /// </summary>
  Student b = new Student();
  b.Name = dictionary["name"].ToString();
  return b;
 /// <summary>
 /// </summary>
  Student b = (Student)obj;
  json.Add("name", b.Name);
  return json;
public class Student
 public Student() { }
 public Student(string name)
  Name = name;
 public string Name
 { get; set; }
This should preserve Student tags between post-backs, and you will also be able to access node.tag.name from client side JavaScript code.
Megan1717
Reply #9 - Jul 7th, 2016 at 3:15pm
Awesome! I will give this a try. Thank you so much for your time, effort, and patience! Very much appreciated.
