Hot Topic (More than 10 Replies) XML Viewer (Read 18206 times)
ManuCavi72
XML Viewer
Aug 1st, 2016 at 4:44pm
Dears,
I have some problems about the use of this application:
after installation and the start, i see the icon down but
it doesn't open the window.
Could you help me about?
Thanks in advance
OS: Win 7 64bit
« Last Edit: Aug 3rd, 2016 at 12:39pm by Forum Admin »
Re: XML Viewer
Reply #1 - Aug 1st, 2016 at 5:45pm
Please open 'control panel -> programs and features ' and check if .NET framework 4 is installed. If you can't find it there, please run this installer -
https://www.microsoft.com/en-us/download/details.aspx?id=17851
if you can already see it listed, try repairing using this tool -
https://www.microsoft.com/en-us/download/details.aspx?id=30135
Re: XML Viewer
Reply #2 - Aug 1st, 2016 at 5:47pm
by 'see the icon down' do you mean it shows as started in the taskbar, but clicking it does not display the window? Can you see xmlviewer.exe process running in the Windows task manager?
ManuCavi72
Re: XML Viewer
Reply #3 - Aug 2nd, 2016 at 12:36pm
Hi Slavcho,
Many thanks for your prompt reply!
More info:
.NET framwork 4 is already installed
I've started also the repairing tool and
I see xmlviewer.exe in the Windows task m,
but XLMviewer has the same problem.
Regards
Manuele
« Last Edit: Aug 3rd, 2016 at 12:40pm by Forum Admin »
Re: XML Viewer
Reply #4 - Aug 2nd, 2016 at 2:24pm
Are you running the viewer directly from its start menu shortcut, or by opening an xml file from Windows Explorer?
ManuCavi72
Re: XML Viewer
Reply #5 - Aug 2nd, 2016 at 4:31pm
Both ways.
Re: XML Viewer
Reply #6 - Aug 3rd, 2016 at 12:30pm
Try this version of the XML Viewer application:
https://mindfusion.eu/_temp/XMLViewer.log.zip
When executed it should create a text log file at this location (by default): C:\Users\<User>\AppData\Local\XmlViewer\log.txt. Can you attach this file here so that we can inspect it.
AAAAAAA
Re: XML Viewer
Reply #7 - May 3rd, 2017 at 5:00pm
I have exactly the same issue.
I have downloaded the application with the log, and this is the content of the log:
[05/03/17 18:54:48] Application start
[05/03/17 18:54:49] Main form constructed
[05/03/17 18:54:49] Run main form
[05/03/17 18:54:49] Main form activated
[05/03/17 18:54:56] Main form activated
Paolo
Re: XML Viewer
Reply #8 - May 5th, 2017 at 7:50am
Please, have a try with this version:
https://mindfusion.eu/_temp/XmlViewer2.log.zip
It should also log the position and state of the application window.
Thank you,
AAAAAAA
Re: XML Viewer
Reply #9 - May 8th, 2017 at 1:03pm
here below the content of the new log:
[05/08/17 14:58:45] Application start
[05/08/17 14:58:46] Main form constructed
[05/08/17 14:58:46] Run main form
[05/08/17 14:58:46] Main form activated
[05/08/17 14:58:46] DesktopBounds: {X=-32000,Y=-32000,Width=160,Height=38}
[05/08/17 14:58:46] WindowState: Normal
[05/08/17 14:58:52] Main form activated
[05/08/17 14:58:52] DesktopBounds: {X=-32000,Y=-32000,Width=160,Height=38}
[05/08/17 14:58:52] WindowState: Normal
[05/08/17 14:58:55] Main form activated
[05/08/17 14:58:55] DesktopBounds: {X=-32000,Y=-32000,Width=160,Height=38}
[05/08/17 14:58:55] WindowState: Normal
[05/08/17 14:59:54] Main form activated
[05/08/17 14:59:54] DesktopBounds: {X=-32000,Y=-32000,Width=160,Height=38}
[05/08/17 14:59:54] WindowState: Normal
[05/08/17 14:59:54] Main form closed
Paolo
Re: XML Viewer
Reply #10 - May 9th, 2017 at 7:40am
Does this happen if you delete the settings.xml file and run the application again? This file is located in the same folder as the log file.
AAAAAAA
Re: XML Viewer
Reply #11 - May 9th, 2017 at 2:30pm
it works fine now.
Thanks a lot
Paolo
Re: XML Viewer
Reply #12 - Jul 19th, 2017 at 12:56pm
It was saving incorrect window position if you shut down the system while the application is minimized. This version fixes it -
https://mindfusion.eu/XMLViewer.zip
rahul.bhatnagar
Re: XML Viewer
Reply #13 - Feb 12th, 2019 at 3:21pm
What is the Latest version and release date for XML Viewer.
