Normal Topic Copy content (Read 5140 times)
sm.eagle
Copy content
Aug 2nd, 2016 at 8:53am
Hi all,
I'm testing your spreadsheet component for WPF and having some difficulties copying cell data with formatting. Using CTRL+C then CTRL+V appears to only copy the cell data. Any hits are appreciated.
Sam
Re: Copy content
Reply #1 - Aug 2nd, 2016 at 11:57am
You can use the following methods to copy and paste text data and formatting:
void Copy()
	var activeSheet = workbookView.ActiveWorksheet;
	var selectionRange = workbookView.Selection.Range;
	var dataObject = new DataObject();
	// Copy data
	var cellData = activeSheet.CopyData(selectionRange);
	dataObject.SetData(cellData);
	// Copy styles
	var styleData = activeSheet.CopyStyles(selectionRange);
	dataObject.SetData(styleData);
	Clipboard.SetDataObject(dataObject, true);
void Paste()
	var dataObject = Clipboard.GetDataObject();
	// Paste data
	if (dataObject.GetDataPresent(typeof(CellData)))
		var cellData = (CellData)dataObject.GetData(typeof(CellData));
		activeSheet.PasteData(workbookView.ActiveCell, cellData);
	// Paste styles
	if (dataObject.GetDataPresent(typeof(StyleData)))
		var styleData = (StyleData)dataObject.GetData(typeof(StyleData));
		activeSheet.PasteStyles(workbookView.ActiveCell, styleData);
Let me know if this helps.
sm.eagle
Re: Copy content
Reply #2 - Aug 2nd, 2016 at 1:43pm
This works nicely, but can it be called in response to the user pressing Ctrl+C and Ctrl+V?
Re: Copy content
Reply #3 - Aug 2nd, 2016 at 2:16pm
You can remove the default Copy and Paste bindings from the WorkbookView:
var copyBinding = workbookView.CommandBindings.Cast<CommandBinding>().Where(b => b.Command == ApplicationCommands.Copy).FirstOrDefault();
if (copyBinding != null)
	workbookView.CommandBindings.Remove(copyBinding);
var pasteBinding = workbookView.CommandBindings.Cast<CommandBinding>().Where(b => b.Command == ApplicationCommands.Paste).FirstOrDefault();
if (pasteBinding != null)
	workbookView.CommandBindings.Remove(pasteBinding);
Then replace them with your own:
workbookView.CommandBindings.Add(new CommandBinding(ApplicationCommands.Copy, OnCopy, OnCanCopy));
workbookView.CommandBindings.Add(new CommandBinding(ApplicationCommands.Paste, OnPaste, OnCanPaste));
In the OnCopy and OnPaste event handlers simply call the Copy/Paste methods above:
private void OnCanCopy(object sender, CanExecuteRoutedEventArgs e)
	e.CanExecute = activeSheet != null && !workbookView.Selection.IsEmpty;
private void OnCopy(object sender, ExecutedRoutedEventArgs e)
	Copy();
private void OnCanPaste(object sender, CanExecuteRoutedEventArgs e)
	e.CanExecute = true;
private void OnPaste(object sender, ExecutedRoutedEventArgs e)
	Paste();
sm.eagle
Re: Copy content
Reply #4 - Aug 3rd, 2016 at 6:10am
Thanks, this works.
