Normal Topic Modify node text programmatically based on nodeID (Read 2224 times)
Shah
Aug 4th, 2016 at 1:06am
How to modify node text programmatically based on specified node id for node that already define the text.
Re: Modify node text programmatically based on nodeID
Reply #1 - Aug 4th, 2016 at 6:39am
If you need to do that on server side -
var node = diagram.FindNodeById(id) as ShapeNode;
if (node != null)
    node.Text = "new text";
Shah
Reply #2 - Aug 9th, 2016 at 3:56am
Thanks for the info Smiley
