Normal Topic Unable to change keyboard language as per culture (Read 8128 times)
yash
Aug 8th, 2016 at 1:33pm
Let  me know what all needs to be checked to set the language on a keyboard as per culture info.
I already tried:
m_VirtualKeyboard.CurrentCulture = new System.Globalization.CultureInfo("nl-BE");
But to no success.
Re: Unable to change keyboard language as per culture
Reply #1 - Aug 8th, 2016 at 5:24pm
Are you using WPF version of the control? With this code I can see AZERTY layout loaded in WinForms control and default QUERTY one remaining in WPF, so I guess WPF version does not contain the built-in layout resource for nl-BE.
yash
Reply #2 - Aug 9th, 2016 at 5:14am
Hi Slavcho,
We are using Virtual Keyboard for WinForms version.
Yash
Reply #3 - Aug 9th, 2016 at 6:10am
Hi Yash,
Okay, are you getting same layout as above but expect another one, or are you seeing altogether different layout? Also are you using latest version of the keyboard released by Mindfusion or an older FPS one?
yash
Reply #4 - Aug 9th, 2016 at 6:35am
Hi Slavcho,
We are using the same layout as can be seen in your screenshot, and its the latest one downloaded.
Its just that the keys of the keyboard do not change as per the culture applied.
Yash
Reply #5 - Aug 9th, 2016 at 7:07am
The keyboard maps virtual key codes to character labels by querying the installed languages. Do you have "Dutch (Belgium)" installed as Windows Input Language? The labels on the WinForms keyboard screenshot looks pretty close to what Windows shows as language layout preview in attached screenshot. If some labels should be different, please let me know which ones and our developer will investigate.
