Normal Topic Line between two ShapeControlPoints overtops the position of the ShapeControlPoints (Read 1865 times)
Cyrinael
Aug 8th, 2016 at 1:51pm
I'm currently trying to use ShapeControlPoints in a ShapeNode in order to drag&drop a line inside a ShapeNode. I have created the ShapeControlPoints and added the corresponding code into the OutlineFormula to draw the line.
This works really really well, but I recognized, that both end of a line are not completely identical with the ShapeControlPoint's position.
I attach my diagram (templates14.tl), as well as my shape library (templates14.tl.sl). Furthermore I add pictures of the issue.
Best Regards,
Cyrinael
Libraries_001.zip (Attachment deleted)
Online
Re: Line between two ShapeControlPoints overtops the position of the ShapeControlPoints
Reply #1 - Aug 8th, 2016 at 6:08pm
The sticking parts seem to be caused by the pen's MiterLimit. I wouldn't expect it to be used in that case, but apparently WPF applies MiterLimit at ends of path figures - the diagram creates a single PathGeometry for the whole formula and new PathFigure for each Moveto command. So FrameworkElement defines 10 as default value for its StrokeMiterLimit property, set it to 1 and the line should end at node's borders -
node.StrokeMiterLimit = 1;
Cyrinael
Reply #2 - Aug 9th, 2016 at 5:56am
Slavcho you are literally a god.
Thank you so much,
Cyrinael
