Normal Topic AllowMultipleSelection = false.. (Read 1786 times)
Shah
Aug 10th, 2016 at 3:13am
I try to disable the diagram from selecting multiple item and I set allowmultipleselection = false. But until now still not success. Is there any sample code that I can refer to.
Thanks.
Re: AllowMultipleSelection = false..
Reply #1 - Aug 10th, 2016 at 9:05am
I can see such property in JavaScript code, but its value is not serialized in JSON so setting it from server side will not work. Try setting this from client side instead -
diagram.selection.allowMultipleSelection = false;
