Normal Topic is this the problem of coding? (Read 2516 times)
kenneth
Sep 21st, 2016 at 8:08am
i instantiate a ShapeNode ,and set the text attributes ,but it can't recognize the language outside of the English language, such as Chinese and Japanese, how do I do it ?
Sample Code:
1:ShapeNode node=new ShapeNode();
2: node.Text="Lee";   // showed normal
3: node.Text="小王";  // Display is not normal
4: node.Text="ちゆき"; // Display is not normal
Re: is this the problem of coding?
Reply #1 - Sep 21st, 2016 at 8:14am
Try solution from http://mindfusion.eu/Forum/YaBB.pl?num=1287546110/1#1
kenneth
Reply #2 - Sep 21st, 2016 at 8:29am
  thank u,according to what you said I solved the problem.  Smiley
