Normal Topic Mindfusion for .net 3.5 (Read 3574 times)
Gravity
Sep 27th, 2016 at 12:43pm
Where can i find information on Mindfusion asp.net components? what it has etc...
Re: Mindfusion for .net 3.5
Reply #1 - Sep 27th, 2016 at 1:23pm
Gravity
Reply #2 - Oct 3rd, 2016 at 2:55pm
Slavcho wrote on Sep 27th, 2016 at 1:23pm:
My mistake, i only wrote in topic name that i need for .net 3.5 : ). I am also interested in comparing it. Is it still possible to get one?
Reply #3 - Oct 4th, 2016 at 8:50am
The trial installation should contain assemblies for both .net 3.5 and .net 4 in respective folders. You can copy the ones you need to your website project's bin folder and use their API then.
Gravity
Reply #4 - Oct 4th, 2016 at 11:49am
Slavcho wrote on Oct 4th, 2016 at 8:50am:
Thanks, i have found a nuget package also, that is very nice. Does these CLR2 and CLR4 versions differ somehow? Does functionality/capabilities differ ?
Reply #5 - Oct 4th, 2016 at 1:40pm
They are built from same source code and shouldn't differ in functionality, except for small things related to different security models of ASP.NET versions.
