Normal Topic Mirror Container Node and all Content (Read 1902 times)
benjamin huser
Oct 11th, 2016 at 6:13am
Hi there
I was wondering if it is possible to mirror a Container Node and all its content. By mirroring i mean flip it vertically/horizontally.
I tried to achieve this via xaml RenderTransform but it did not seem to have any effect...
Thanks for your help
Re: Mirror Container Node and all Content
Reply #1 - Oct 11th, 2016 at 9:08am
You will have to set symmetric child nodes' positions around the container's center -
void SetCenter(DiagramNode node, Point center)
	var c = node.GetCenter();
	var r = node.Bounds;
	r.X += center.X - c.X;
	r.Y += center.Y - c.Y;
	node.SetBounds(r, false, false);
void FlipChildrenX(ContainerNode container)
	var bounds = container.Bounds;
	bounds.Y += container.CaptionHeight;
	bounds.Height -=container.CaptionHeight;
	foreach (DiagramNode child in container.SubordinateGroup.AttachedNodes)
		var newChildCenterX = bounds.Right - (child.GetCenter().X - bounds.Left);
		SetCenter(child, new Point(newChildCenterX, child.GetCenter().Y));
A RenderTransform will not affect child nodes because they are not a part of container's visual tree. It's not likely you'd like the result anyway because it also flips the nodes texts making them unreadable. If that's what you are after, you could still apply mirror transform to individual child nodes.
benjamin huser
Reply #2 - Oct 11th, 2016 at 10:54am
Hi Slavcho
thanks for the clarification and the sample code.
I will test it right away  Smiley
Regards
Benjamin
