Normal Topic Tooltip that does not disappear automatically (Read 2999 times)
RickSalut
Oct 12th, 2016 at 8:13pm
Hi, I'm looking for a method or property that I could set on a DiagramNode (or Diagram) that will prevent a node's tooltip to disappear after a few seconds (event if the cursor is still over it).
Another solution would be to set a higher delay (in seconds) before the tooltip disappear, that would also be ok for my need.
Is it possible?  Thank you.
Re: Tooltip that does not disappear automatically
Reply #1 - Oct 13th, 2016 at 1:21pm
The diagram registers itself with Swing's standard ToolTipManager to show tooltips; you should be able to do that with its dismissDelay property.
