Normal Topic Dynamic RoutingOptions.GridSize? (Read 2004 times)
Kim Lillås
Oct 18th, 2016 at 7:10am
I am fiddling around with some routing optimization, the problem I am facing now is that a larger RoutingOptions.GridSize gives a small waiting time and acceptable routings for links which travel a large distance, but the routing might fail if I link two nodes which are very close to each other.
I was thinking of a dynamic GridSize based on the distance between nodes to fix this, does this make sense or am I looking in the wrong direction? Is this per default supported in the diagramming component, or do I have to add it manually?
Greetings,
Kim
Online
Re: Dynamic RoutingOptions.GridSize?
Reply #1 - Oct 18th, 2016 at 9:24am
Hi Kim,
There's no built-in dynamic grid size. If you are generating the diagram programmatically, you could make sure your nodes are placed at least at twice the grid-size distance, or otherwise find the min. distance between nodes and set grid-size to half of it so that grid squares between min-distance nodes are not marked as obstacles.
FYI GridRouter runs standard A* search algorithm; you can see how it traverses the grid in animated image here -
https://en.wikipedia.org/wiki/A*_search_algorithm
Kim Lillås
Reply #2 - Oct 18th, 2016 at 10:34am
Thanks!
