Normal Topic How to change bounding rectangle size (canvas mode)? (Read 6550 times)
CrushJelly
Oct 31st, 2016 at 12:30pm
I created my own shape library and loaded my shapes.
When I draw my custom rectangle, the shape of it it's good, but the bounding rectangle is way too big (pic. rectBounds),
is there a possibility to decrease the size of the bounding rectangle?
PS. I tried to increasing the size of my rectangle, but the rounded sides gets messed up.
I want to have rounded rectangle like in Silverlight diagraming version (pic. roundedRectangleFromSilverLight.png).
« Last Edit: Oct 31st, 2016 at 2:11pm by CrushJelly »
Re: How to change bounding rectangle size (canvas mode)?
Reply #1 - Oct 31st, 2016 at 6:18pm
Coordinates of shape definitions in shape libraries are specified as percentage of node's bounding rectangle, so it seems you've set something like 45% height. To get a non-square shape for nodes created by user's drag-and-drop, set the NodeListView.DefaultNodeSize property using standard Rectangle or RoundRect shapes, or resize the nodes from NodeCreatedScript event.
CrushJelly
Reply #2 - Nov 2nd, 2016 at 2:03pm
Slavcho wrote on Oct 31st, 2016 at 6:18pm:
Can I set node size through server side, like register event?
Because, I have custom property ShapeType, I try to get it on the NodeCreatedScript event, but there is nothing, I check serialization and seems that ShapeType is added to json Dictionary, but there is no value in the end.
The ShapeType property is set on server side, but I tried setting the property in js, got same result.
Reply #3 - Nov 2nd, 2016 at 3:10pm
Check if your JavaScriptConverter code gets called (the one you register with RegisterConverters) - it's where the custom property should be serialized to send to client side. You must also override fromJson in JavaScript to read it.
With latest build of the script, you could set Bounds on server side, and set IconSize and DefaultNodeSize values of the NodeListView to null from client side, to make it use nodes' Bounds instead. We should have updated version of the .NET assemblies that will let you do that entirely from server side later today or tomorrow.
CrushJelly
Reply #4 - Nov 3rd, 2016 at 7:54am
Quote:
Slavcho wrote on Nov 2nd, 2016 at 3:10pm:
I need to set the shapeNode size when dragAndDroping the ShapeNode, I tried registering server-side event but it didn't work, it only worked if I set the JS event,
so it's not available on server-side, or I am doing something wrong?
Yes converter gets called:
Quote:
I checked serialization and seems that ShapeType is added to json Dictionary, but there is no value in the end.
It gets correct object type in javascript when I use "node.getType();"
What I did wrong?, I almost all the code is copied from Mindfusion sample IconNode,
but I just set the value of the property in the .cs.
Converter Code:
 public class MyShapeNodeConverter : ShapeNodeConverter
        public MyShapeNodeConverter (DiagramView view) : base(view)
        public MyShapeNodeConverter (DiagramView view, bool addInstanceId) : base(view, addInstanceId)
        public override IEnumerable<Type> SupportedTypes
            get
                return new List<Type>(new[] { typeof(DLXShapeNode) });
        public override object Deserialize(IDictionary<string, object> dictionary, Type type, JavaScriptSerializer serializer)
            var customNode = (MyShapeNode)base.Deserialize(dictionary, type, serializer);
            return customNode;
        public override IDictionary<string, object> Serialize(object obj, JavaScriptSerializer serializer)
            var shapeNode = obj as MyShapeNode;
            if (shapeNode == null)
                return null;
            var json = base.Serialize(obj, serializer);
            if (json == null)
                return null;
             json.Add("ShapeType", shapeNode.ShapeType);
            return json;
JS class:
MyShapeNode = function () {
    MyShapeNode.initializeBase(this);
MyShapeNode.prototype =
    initialize: function () {
        MyShapeNode.callBaseMethod(this, 'initialize');
    dispose: function () {
        MyShapeNode.callBaseMethod(this, 'dispose');
    //properties
    getTitle: function() {
        return this.Title;
    setTitle: function(value) {
        if (this.Title !== value)
            this.Title = value;
    getEmailSubject: function () {
        return this.EmailSubject;
    setEmailSubject: function (value) {
        if (this.EmailSubject !== value)
            this.EmailSubject = value;
    getShapeType: function () {
        return this.ShapeType;
    setShapeType: function (value) {
        if (this.ShapeType !== value)
            this.ShapeType = value;
    getEmailBody: function () {
        return this.EmailBody;
    setEmailBody: function (value) {
        if (this.EmailBody !== value)
            this.EmailBody = value;
    getDescription: function () {
        return this.Description;
    setDescription: function (value) {
        if (this.Description !== value)
            this.Description = value;
    toJson: function () {
        var data = MyShapeNode.callBaseMethod(this, "toJson");
        data.Title = this.Title;
        data.EmailSubject = this.EmailSubject;
        data.EmailBody = this.EmailBody;
        data.ShapeType = this.ShapeType;
        data.Description = this.Description;
        data.nodeType = this.nodeType;
        return data;
    fromJson: function (json) {
        MyShapeNode.callBaseMethod(this, "fromJson", [json]);
        this.setTitle(json.Title);
        this.setShapeType(json.ShapeType);
        this.setEmailSubject(json.EmailSubject);
        this.setEmailBody(json.EmailSubject);
        this.setDescription(json.Description);
        return json;
    updateCanvasElements: function (node) {
        MyShapeNode.callBaseMethod(this, 'updateCanvasElements');
if (typeof (Sys) !== 'undefined')
    Sys.Application.notifyScriptLoaded();
My testing script:
function onNodeCreated(sender, args) {
            var node = args.getNode();
            alert(node.getShapeType());
« Last Edit: Nov 3rd, 2016 at 2:44pm by CrushJelly »
Reply #5 - Nov 3rd, 2016 at 12:40pm
Quote:
rounded sides gets messed up. I want to have rounded rectangle like in Silverlight diagraming version (pic. roundedRectangleFromSilverLight.png).
This build no longer stretches the corner arcs when you resize a round-rect shape if that's what you meant -
https://mindfusion.eu/_beta/jsdiag271.zip
CrushJelly
Reply #6 - Nov 3rd, 2016 at 1:24pm
Slavcho wrote on Nov 3rd, 2016 at 12:40pm:
Look my:
"Re: How to change bounding rectangle size (canvas mode)?
Reply #4 - Today at 8:54am"
Reply #7 - Nov 3rd, 2016 at 7:13pm
Quote:
I need to set the shapeNode size when dragAndDroping the ShapeNode, I tried registering server-side event but it didn't work, it only worked if I set the JS event, so it's not available on server-side, or I am doing something wrong?
Enable AutoPostback to get DiagramView.NodeCreated server event raised in Canvas mode.
Quote:
What I did wrong?, I almost all the code is copied from Mindfusion sample IconNode, but I just set the value of the property in the .cs.
I guess you might have to return typeof(MyShapeNode) instead of DLXShapeNode from SupportedTypes implementation. Please find my test project transferring the custom property correctly -
https://mindfusion.eu/_samples/MyShapeNode.zip
That will work if you create node on server side, and examine the property of corresponding JS instance. If you draw a MyCustomNode instance on client-side, you'll get undefined message from NodeCreatedScript=onNodeCreated because it does not run your C# constructor; you'd have to initialize fields from JS constructor instead.
CrushJelly
Reply #8 - Nov 4th, 2016 at 8:36am
Slavcho wrote on Nov 3rd, 2016 at 7:13pm:
I am setting ShapeType through constructor on server side and putting all the ShapeNodes in the nodeListView.
So I need to to create constructor with parameters in shapeNodes JS class and pass the ShapeType?..., I tried it and I get some random object that has items collection and fills it with ShapesNodes, but how I get individual node?
PS. How to turn off automatic mouse drag draw?, do I need to set custom behavior and override StartDraw?
« Last Edit: Nov 4th, 2016 at 9:50am by CrushJelly »
Reply #9 - Nov 4th, 2016 at 10:11am
Ah, the NodeListView calls a clone() method when you drag and drop, so you'll need to copy your added properties from its override. Here's how ShapeNode implements it -
clone: function ()
    var copy = mflayer.callBaseMethod(ShapeNode, this, "clone", []);
    copy.setShape(this.shape.id);
    copy.setImageLocation(this.imageLocation);
    copy.setTransparent(this.transparent);
    copy.setImageAlign(this.imageAlign);
    copy.setRotateText(this.rotateText);
    copy.setRotateImage(this.rotateImage);
    copy.setImageContent(this.imageContent);
    copy.setEnableStyledText(this.getEnableStyledText());
    return copy;
Set the Behavior property to something like DrawLinks, Pan or SelectOnly.
