Normal Topic Container Caption sizing (Read 1780 times)
j poz
Oct 31st, 2016 at 4:15pm
When I set the Caption of an empty ContainerNode I notice the size of the container doesn't change right away to fit the Caption, even if I call UpdateBounds. Is there another call I should make after setting the Caption?
Re: Container Caption sizing
Reply #1 - Oct 31st, 2016 at 6:24pm
ContainerNode's size does not depend on Caption and will not update automatically. You could call Diagram.MeasureString to find what size will fit the text and then calculate new Bounds value from it.
