Normal Topic Cannot display Chinese texts (Read 5680 times)
Shafi
Nov 8th, 2016 at 3:34pm
I would like to know how can we support Chinese texts in the Cell.
See attachment
Re: Cannot display Chinese texts
Reply #1 - Nov 8th, 2016 at 4:59pm
Make sure you are using fonts that contain Chinese glyphs. The diagram's default Font value "Arial" does not contains them and draws placeholders. Set some Unicode fonts and the texts should show -
TableNode t = diagram.getFactory().createTableNode(10, 10, 20, 30, 1, 3);
t.getCell(0, 0).setFont(new Font("Arial", Font.PLAIN, 4)); // this one does not render correctly
t.getCell(0, 0).setText("测试");
t.getCell(0, 1).setFont(new Font("MingLiU", Font.PLAIN, 4));
t.getCell(0, 1).setText("测试");
t.getCell(0, 2).setFont(new Font("Arial Unicode", Font.PLAIN, 4));
t.getCell(0, 2).setText("测试");
Shafi
Reply #2 - Nov 11th, 2016 at 11:17am
Thanks for the reply. Adding the Font to TableNode works, but adding it to the Cell overlaps the characters for some reason. (Tried with Arial Unicode).
Reply #3 - Nov 11th, 2016 at 11:29am
Cells draw text using table's font when their own isn't set, so there shouldn't be any difference if you assign same font. Do you mean characters in same cell overlapping each other, or a cell's text overflowing to next one and overlapping neighboring cells' text?
Shafi
Reply #4 - Nov 14th, 2016 at 10:21am
Yes, the characters in the same cell overlaps with each other when I set the Arial Unicode Font to Cell. For now, adding the same Font to TableNode works (which is enough for my requirement), but there is a potential of a bug here.
PS: I have numbers and Chinese Text in the same row of the Cell. I dont know if this matters because even removing numbers caused overlap.
Reply #5 - Nov 15th, 2016 at 10:26am
I could not reproduce overlapping glyphs. What diagram.MeasureUnit and font.Size values are you using, and could you post the exact string, or attach a saved diagram xml file?
