Normal Topic Routing causes more than necessary lines for short distances (Read 3842 times)
Kim Lillås
Nov 9th, 2016 at 11:39am
Even with high values for the RoutingOptions.TurnCost, it creates an unnecessary turn for the simple example I attached.
If I move the left hand node one step further away, the routing is "correct" in the sense that it avoids the unnecessary extra turn.
Any idea what might be causing this behaviour for short distance links routings?
Note: The little black rectangle in the middle of the picture is a node, and there is a total of two links in the picture. It is the left hand link routing which is "wrong".
Online
Re: Routing causes more than necessary lines for short distances
Reply #1 - Nov 10th, 2016 at 10:44am
End points are selected before the actual evaluation of costs. I think it decides to move the link to the bottom of small rectangle because it's more in vertical direction than horizontal one in first image (dx < dy). If link segments adjacent to the small node should be always horizontal, try assigning anchor points to its left and right sides.
Kim Lillås
Reply #2 - Nov 10th, 2016 at 11:05am
Thanks for the answer. No, they do not have to be horizontal. The main thing is that it minimizes the amount of lines to reach its target.
I guess I could programmatically evaluate different anchor points and choose the one with the lowest routing cost. Is the routing cost publicly available?
//Kim
Online
Reply #3 - Nov 10th, 2016 at 11:57am
What are you using that node for? If it's just to force the link path through a specific location of the diagram, we could instead add some API to the LinkRouter classes for that.
Kim Lillås
Reply #4 - Nov 10th, 2016 at 12:23pm
Hallo,
Right now it is a visualization of our "Connectivity Node", which is primarily used to connect 2 - n nodes together.
You can see an example in the picture where the connectivity node is used to connect 4 other nodes together.
I am free to manually move the connectivity node after it has been initially created.
Online
Reply #5 - Nov 11th, 2016 at 12:14pm
Our developer will add some option to evaluate different end points for better costs. We should have an update next week.
Online
Reply #6 - Nov 16th, 2016 at 10:55am
Try the RoutingOptions.EvaluateFarPoints option from this build -
https://mindfusion.eu/_beta/wpfdiag342.zip
It makes GridRouter evaluate points from all sides of link's nodes and select the route with lowest cost. Routing becomes much slower though; we'll try to optimize for official release.
