Normal Topic ContainerNode Adjustments (Read 3606 times)
benjamin huser
Nov 16th, 2016 at 10:01am
Hi there
we have a custom container node (by deriving from ContainerNode) and I have two questions.
First: Is it possible to somehow have a transparent background on the rendered container, so we still would see the Grid that is set on the Diagram?
And the second one is an issue with when we draw links. So whenever we wanna draw a link it tries to connect to somewhere on the container itself, but we don't want this container to have any anchor points at all. I tried setting the AnchorPoints property to both null and to initialize an Empty Anchor pattern, but both did not work.
Thanks for your help
Re: ContainerNode Adjustments
Reply #1 - Nov 16th, 2016 at 11:08am
Hi!
Try following properties -
//container.Brush = new SolidColorBrush(Color.FromArgb(100, 255, 255, 255));
container.Brush = Brushes.Transparent;
container.AllowIncomingLinks = false;
Setting AnchorPattern to null should work too if diagram's AllowUnanchoredLinks is disabled.
benjamin huser
Reply #2 - Nov 16th, 2016 at 11:37am
Hi Slavcho
both things work now, thanks for your help Smiley
Regards
benjamin huser
Reply #3 - Nov 16th, 2016 at 11:57am
Hi Slavcho
just one thing I just realized was that since I changed:
I have an exception as soon as I hover with my mouse over any node in the Diagram (you don't need to click, just hover is enough) when try to validate the anchor point (I guess you check if you display a different handle depending on if the mouse is on an actual anchor point...).
I put the exception message as a attachement.
Whenever we try to access e.Destination or e.ChangingDestination there seems to be some internal exception. You see some commented out code above, if I enable this code everything works fine.
Best Regards
Reply #4 - Nov 16th, 2016 at 2:48pm
This event is raised with e.Link set to null when hovering over a node, just to determine whether any outgoing link could be drawn and show respective mouse pointer. For time being add an "if (e.Link == null) return" check in the beginning of handler. We'll fix ChangingOrigin / ChangingDestination to handle null links too, but you might need to verify that anyway because the screenshot shows access to e.Link members from the event code.
benjamin huser
Reply #5 - Nov 16th, 2016 at 2:53pm
Hi Slavcho
ok I quickly tried and it works.
Thanks for your help and your quick response.
