Normal Topic How to bind DiagramNode.Bounds property? (Read 4942 times)
roger huber
Nov 10th, 2016 at 8:14pm
Hi!
I don't get a binding to work. I set up the binding in my custom Node (that inherrits from DiagramNodeAdapter):
var boundsBinding = new Binding(nameof(NodeViewModel.Bounds))
  Source = NodeViewModel,
  Mode = BindingMode.OneWay,
  Converter = new RelativeToAbsoluteNodePositionConverter(),
  ConverterParameter = NodeViewModel
SetBinding(BoundsProperty, boundsBinding);
The NodeViewModel's Bounds property value is fetched the very first time after setting the binding (and the converter is executed). However, if I later fire the PropertyChanged event in the NodeViewModel, the property won't be accessed. There are no swallowed binding exceptions and the NodeViewModel that is used as source for the binding is the same instance that fires the PropertyChanged event.
Shouldn't that work?
Roger
Re: How to bind DiagramNode.Bounds property?
Reply #1 - Nov 11th, 2016 at 11:13am
Hi!
Our bad; it should work with this build -
https://mindfusion.eu/_beta/wpfdiag342.zip
roger huber
Reply #2 - Nov 16th, 2016 at 3:19pm
Hi Slavcho,
Partial success. Given the structure Diagram->ContainerNode->DiagramNodeAdapter, the DiagramNode.BoundsProperty binding does work now.
But I have still an issues:
As soon as I move ContainerNode, the node that is attached to the ContainerNode is not moved although PropertyChanged event is fired in the NodeViewModel.
Roger
Reply #3 - Nov 17th, 2016 at 10:17am
Moving the container interactively also moves the child for me. Do you mean moving it through a ContainerNode.Bounds binding too?
roger huber
Reply #4 - Nov 17th, 2016 at 11:54am
I attached two pictures. Picture #1 shows the working use case whereas picture #2 shows the use case in that the binding does not work any longer.
In each picture you can see two MindFusion.Diagramming.Wpf.Diagram instances. Moving a node in one diagram will update the second diagram (following the MVVM pattern).
Reply #5 - Nov 18th, 2016 at 9:44am
I'm confused by the numbering Smiley Anyway just playing with Bounds and bindings here's what I'm seeing (without involving ContainerNodes) -
1. Mode = BindingMode.OneWay
2. NodeViewModel.Bounds = new_value
3. node.Bounds local value is a BindingExpression, node position updates successfully from it
4. I move the node, Bounds local value becomes a Rect
5. NodeViewModel.Bounds assignment no longer updates node position because BindingExpression has been removed from the dependency property
1. Mode = BindingMode.TwoWay
4. I move the node, and since binding is two-way the property assignment updates NodeViewModel.Bounds
5. NodeViewModel.Bounds assignment still updates node position because the property local value is a BindingExpression.
So I'm guessing if your binding mode is still OneWay as in first post, try changing it to TwoWay. You can verify if binding is active by examining the result of node.ReadLocalValue(DiagramNode.BoundsProperty) - should be an instance of System.Windows.Data.BindingExpression.
roger huber
Reply #6 - Nov 18th, 2016 at 10:57am
Why does moving a MindFusion.Diagramming.Wpf.DiagramNodeAdapter on the canvas replace the BindingExpression by a Rect instance? This is something that I don't expect. I think if I move the ContainerNode, the child node's Bound's property will be changed from BindingExpresson to Rect as well and therefore is not updated any more.
The reason why I'm using BindingMode.OneWay is because I want to set NodeViewModel.Bounds after MindFusion.Diagramming.Wpf.DiagramBase.NodeModified has been fired. I don't want the source of the binding to be updated when the user is still moving a node.
Reply #7 - Nov 18th, 2016 at 1:06pm
It's how WPF dependency property system works -
var depObj1 = new BindTest();
var model1 = new BindTestModel();
var binding1 = new Binding("TestValue")
	Source = model1,
depObj1.SetBinding(BindTest.TestValueProperty, binding1);
model1.TestValue = 1;
Debug.WriteLine(depObj1.ReadLocalValue(BindTest.TestValueProperty)); // BindingExpression
depObj1.TestValue = 1;
Debug.WriteLine(depObj1.ReadLocalValue(BindTest.TestValueProperty)); // no longer BindingExpression
var depObj2 = new BindTest();
var model2 = new BindTestModel();
var binding2 = new Binding("TestValue")
	Source = model2,
depObj2.SetBinding(BindTest.TestValueProperty, binding2);
model2.TestValue = 2;
Debug.WriteLine(depObj2.ReadLocalValue(BindTest.TestValueProperty));  // BindingExpression
depObj2.TestValue = 2;
class BindTest : FrameworkElement
	public static DependencyProperty TestValueProperty = DependencyProperty.Register(
		"TestValue", typeof(int), typeof (BindTest));
	public int TestValue
		get { return (int) GetValue(TestValueProperty); }
		set { SetValue(TestValueProperty, value); }
class BindTestModel : INotifyPropertyChanged
		get { return testValue; }
		set
			testValue = value;
			if (PropertyChanged != null)
				PropertyChanged(this, new PropertyChangedEventArgs("TestValue"));
	private int testValue;
	public event PropertyChangedEventHandler  PropertyChanged;
Calling SetValue(DependencyProperty) on two-way BindingExpression updates the model and keeps the expression. Calling it on one-way binding expression replaces the local BindingExpression value with the specified value and it's no longer bound.
I guess if you want to keep the one-way mode, you could rebind again from NodeModified handler.
