Normal Topic diagram translation (Read 2382 times)
Jim li
diagram translation
Dec 12th, 2016 at 3:54am
I want to achieve the function when left mouse button press the diagram Translation (current i only can translation by scroll bar),is there any api can i use?
Re: diagram translation
Reply #1 - Dec 12th, 2016 at 6:31am
If you want to scroll it yourself in response to mouse events, set the ScrollX and ScrollY properties of DiagramView. If you set the Behavior property to Pan, users will be able to scroll by dragging with the mouse inside the diagram canvas area. You can also change scroll position using the Overview and ZoomControl widgets, by respectively moving the tracker rectangle or clicking the arrow buttons.
Jim li
Reply #2 - Dec 12th, 2016 at 7:08am
It helps me,Thank you very much.
