Normal Topic Keep in sync with Xamarin.Forms version? (Read 9765 times)
Heli
Dec 20th, 2016 at 10:58am
as far as I know, the current MindFusion Xamarin Calendar control is V1.1 built against Xamarin.Forms 2.3.2.127
As of Dec. 6th, the Xamarin.Forms stable version is 2.3.3.175
Could you please build against this new Xamarin.Forms version?
Maybe you can provide a Nuget package (and update it regularly) to keep in sync with the current Xamarin.Forms stable version?
Heli
Re: Keep in sync with Xamarin.Forms version?
Reply #1 - Dec 21st, 2016 at 7:37am
We will roll a new build soon.
Heli
Reply #2 - Jan 20th, 2017 at 8:23pm
may I ask when the new build will be available?
Heli
Reply #3 - Jan 23rd, 2017 at 1:57pm
We will release by the end of the week.
Reply #4 - Jan 27th, 2017 at 2:41pm
Please, have a look a this pre-release build: https://mindfusion.eu/_temp/Xamarin.Calendar.beta.zip. It is built against the latest Xamarin.Forms 2.3.3.180.
Heli
Reply #5 - Jan 29th, 2017 at 8:35pm
Hi Meppy,
I could successfully include this into my app solution with Xamarin.Forms 2.3.3.180.
A minimalistic calendar (taken from your Calendar sample) is shown on Android, but I have problems on iOS with my Master-Detail driven app.
Test solution is provided by PM.
Heli
Reply #6 - Jan 30th, 2017 at 8:58am
Have you tried loading the iOS assembly explicitly (by instantiating the CalendarRenderer class, for example)? It seems that Xamarin fails to load the platform assembly when running the iOS version and the control is unable to find its renderer. In the AppDelegate.cs class add the following line before calling Xamarin.Forms init:
// Make sure the assembly is loaded...
var notUsed = new CalendarRenderer();
global::Xamarin.Forms.Forms.Init();
Heli
Reply #7 - Jan 30th, 2017 at 7:22pm
Hi Meppy,
that way it works!
Thank you!
Heli
