Normal Topic [TypeScript/Angular2] Diagram Library throws compile time error (Read 2479 times)
Shafi
Feb 14th, 2017 at 9:00am
I installed the diagram-library using the npm install command. But i cant resolve the MindFusion namespace in my ts file. Do I need any imports or some other configuration for using this package?
Re: [TypeScript/Angular2] Diagram Library throws compile time error
Reply #1 - Feb 14th, 2017 at 10:39am
Have you added jsdiag.d.ts reference? This compiled successfully in our test with main .ts file in project's root folder and diagram-library npm-installed there -
/// <reference path="node_modules/diagram-library/jsdiag.d.ts" />
var Diagram = MindFusion.Diagramming.Diagram;
Shafi
Reply #2 - Feb 14th, 2017 at 12:08pm
Thanks. That worked  Smiley
One more question about compatibility:
In previous MindFusion versions, there was the MindFusion.Collections API which I cannot find anymore.Can you please tell me what is this API changed to?
Reply #3 - Feb 14th, 2017 at 1:27pm
I guess you were using Collections directly from JavaScript at some point. We've never had it defined for TypeScript, we'll try to add it to d.ts file for upcoming release.
